Journal articles
Simulation and Optimization of Stall Control for an Airfoil with a Synthetic Jet
Abstract : This study concerns the simulation and optimization of stall control, using a synthetic jet. The flow is simulated by solving unsteady Reynolds-averaged Navier-Stokes equations with a near-wall low-Reynolds number turbulence closure. The flow around a NACA 0015 airfoil, including a synthetic jet located at 12% of the chord, is studied for a Reynolds number Re = 8.96 10 5 and for angles of attack from 12 to 24 degrees. The optimization of the control parameters (momentum coefficient, frequency, angle w.r.t. the wall) is intended, by coupling an automatic optimization algorithm with the flow solver. A significant improvement of the control efficiency is obtained (maximum lift increased of 34% and stall delayed from 19 • to 22 • w.r.t. the initial controlled flow). A Physical analysis of the flow is performed to characterize the optimal control process found.
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01730884
Contributor : Régis Duvigneau Connect in order to contact the contributor
Submitted on : Wednesday, March 14, 2018 - 9:17:40 AM
Last modification on : Wednesday, September 14, 2022 - 3:08:05 PM
Long-term archiving on: : Friday, June 15, 2018 - 12:24:05 PM
File
ast_1362.pdf
Identifiers
Citation
Régis Duvigneau, Michel Visonneau. Simulation and Optimization of Stall Control for an Airfoil with a Synthetic Jet. Aerospace Science and Technology, Elsevier, 2006, 10 (4), pp.279-287. ⟨10.1016/j.ast.2006.01.002⟩. ⟨hal-01730884⟩
Share
Metrics
Record views
170
Files downloads
180
