Numerical method for coupled fluid flow, heat transfer and stress analysis using unstructured moving meshes with cells of arbitrary topology, Computer Methods in Applied Mechanics and Engineering, vol.125, issue.1-4, pp.235-255, 1995. ,
DOI : 10.1016/0045-7825(95)00800-G
Direct Search Methods on Parallel Machines, SIAM Journal of Optimization, vol.1, issue.4, pp.448-474, 1991. ,
DOI : 10.1007/978-3-642-48417-9_2
URL : http://www.dtic.mil/cgi-bin/GetTRDoc?AD=ADA453084&Location=U2&doc=GetTRDoc.pdf
Active flow control applied to an airfoil, 36th AIAA Aerospace Sciences Meeting and Exhibit, pp.98-0210, 1998. ,
DOI : 10.2514/3.13393
Shape optimization of incompressible and turbulent flows using the simplex method, 15th AIAA Computational Fluid Dynamics Conference, 2001. ,
DOI : 10.1017/S0022112083000294
On the role played by turbulence closures for hull shape optimization at model and full scale, Journal of Marine Science and Technology, vol.8, issue.1, 2003. ,
Active Flow Control of Wing Separated Flow, Volume 1: Fora, Parts A, B, C, and D, 2003. ,
DOI : 10.1115/FEDSM2003-45237
Characterization of a compact, high power synthetic jet actuator for flow separation control, AIAA Paper, pp.2002-0127, 2002. ,
Effects of Surface Blowing/Suction on the Aerodynamics of Helicopter Rotor Blade-Vortex Interactions (BVI) ??? A Numerical Simulation, Journal of the American Helicopter Society, vol.42, issue.2, pp.182-194, 1997. ,
DOI : 10.4050/JAHS.42.182
Optimum aerodynamic design using the Navier-Stokes equation. Theorical and Computational Fluid Dynamics, pp.213-237, 1998. ,
DOI : 10.2514/6.1997-101
URL : http://aero-comlab.stanford.edu/Papers/reno97.nsdesign.pdf
Aerodynamic Design Optimization on Unstructured Meshes Using the Navier-Stokes Equations, AIAA Journal, vol.37, issue.11, pp.1411-1419, 1999. ,
DOI : 10.2514/6.1997-2232
Active control of flow separation over an airfoil, 1999. ,
Delay of airfoil stall by periodic excitation, Journal of Aircraft, vol.5, issue.4, pp.691-707, 1996. ,
DOI : 10.2514/6.1993-3264
Post-stall lift enhancement on an airfoil by local unsteady control, part i. lift, drag and pressure characteristics, 1997. ,
DOI : 10.2514/6.1997-2064
