End of range defects in Ge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Physics Année : 2009
We show that the solid-phase epitaxial regrowth of amorphous layers created by ion implantation in Ge results in the formation of extended defects of interstitial-type. During annealing, these defects evolve in size and density following, as in Si, an Ostwald ripening mechanism. However, this process becomes nonconservative as the annealing temperature increases to 600 °C. This suggests that the recombination/annihilation of Ge interstitial atoms becomes important at these temperatures. These results have important implications for the modeling of diffusion of implanted dopants in Ge.
1.3153985.pdf (434.45 Ko) Télécharger le fichier
hal-01736054 , version 1 (23-03-2018)
S. Koffel, Nikolay Cherkashin, Florent Houdellier, Martin Hÿtch, Gérard Benassayag, et al.. End of range defects in Ge. Journal of Applied Physics, 2009, 105, pp.126110. ⟨10.1063/1.3153985⟩. ⟨hal-01736054⟩
128 Consultations
122 Téléchargements
