Two Tools for Semi-automatic Phonetic Labelling of Large Corpora - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Odile Mella
Dominique Fohr
This paper presents two tools allowing a reliable semi-automatic labelling of large corpora : an automatic HMM-based labelling tool and an assessment and decision system to validate the automatically labelled sentences. This decision system uses the results supplied by another automatic labeller and compares their results with a parametrisable comparison process. We also propose an generic methodology to improve the labelling accuracy and to reduce the step of manual verification.
lrec98.pdf (415.99 Ko) Télécharger le fichier
hal-01737011 , version 1 (21-03-2018)
  • HAL Id : hal-01737011 , version 1
Odile Mella, Dominique Fohr. Two Tools for Semi-automatic Phonetic Labelling of Large Corpora. First international conference on language resources and evaluation, May 1998, Granada, Spain. ⟨hal-01737011⟩
Collections
INRIA INRIA2
445 Consultations
90 Téléchargements
