A hierarchy of lower bounds for sublinear additive spanners, Proceedings of the Twenty-Eighth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.568-576, 2017. ,
VCdimension and shortest path algorithms, ICALP, vol.6755, pp.690-699, 2011. ,
Highway dimension and provably efficient shortest path algorithms, J. ACM, vol.63, issue.5, 2016. ,
DOI : 10.1145/2985473
Highway dimension, shortest paths, and provably efficient algorithms, Proceedings of the Twenty-First Annual ACM-SIAM Symposium on Discrete Algorithms, SODA 2010, pp.782-793, 2010. ,
DOI : 10.1137/1.9781611973075.64
URL : https://epubs.siam.org/doi/pdf/10.1137/1.9781611973075.64
Dynamic and historical shortest-path distance queries on large evolving networks by pruned landmark labeling ,
, 23rd International World Wide Web Conference, WWW '14, pp.237-248, 2014.
Optimal preprocessing for answering on-line product queries, 1987. ,
Sublinear distance labeling, 24th Annual European Symposium on Algorithms, ESA 2016, vol.57, pp.1-5, 2016. ,
Algorithmic and hardness results for the hub labeling problem, Proceedings of the Twenty-Eighth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.1442-1461, 2017. ,
Planar spanners and approximate shortest path queries among obstacles in the plane, Algorithms -ESA '96, Fourth Annual European Symposium, vol.1136, pp.514-528, 1996. ,
Ultrafast shortest-path queries via transit nodes, The Shortest Path Problem, Proceedings of a DIMACS Workshop, vol.74, pp.175-192, 2006. ,
DOI : 10.1090/dimacs/074/07
Transitive-closure spanners, SIAM J. Comput, vol.41, issue.6, pp.1380-1425, 2012. ,
DOI : 10.1137/110826655
URL : http://arxiv.org/pdf/0808.1787
Trade-offs in non-reversing diameter, Nord. J. Comput, vol.1, issue.1, pp.111-134, 1994. ,
Many distances in planar graphs, Algorithmica, vol.62, issue.1-2, pp.361-381, 2012. ,
Shortest paths in digraphs of small treewidth. part I: sequential algorithms, Algorithmica, vol.27, issue.3, pp.212-226, 2000. ,
Computing on a free tree via complexity-preserving mappings, Algorithmica, vol.2, pp.337-361, 1987. ,
Shortest path queries in planar graphs, Proceedings of the ThirtySecond Annual ACM Symposium on Theory of Computing, pp.469-478, 2000. ,
Using selective path-doubling for parallel shortest-path computations, J. Algorithms, vol.22, issue.1, pp.30-56, 1997. ,
Polylog-time and near-linear work approximation scheme for undirected shortest paths, J. ACM, vol.47, issue.1, pp.132-166, 2000. ,
Reachability and distance queries via 2-hop labels, SIAM J. Comput, vol.32, issue.5, pp.1338-1355, 2003. ,
Fast and compact exact distance oracle for planar graphs, 58th IEEE Annual Symposium on Foundations of Computer Science, pp.962-973, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-02169530
Robust distance queries on massive networks, Algorithms -ESA 2014 -22th Annual European Symposium, vol.8737, pp.321-333, 2014. ,
On-line algorithms for shortest path problems on planar digraphs, Graph-Theoretic Concepts in Computer Science, 22nd International Workshop, WG '96, vol.1197, pp.151-165, 1996. ,
Hopsets with constant hopbound, and applications to approximate shortest paths, IEEE 57th Annual Symposium on Foundations of Computer Science, FOCS, pp.128-137, 2016. ,
Linear-size hopsets with small hopbound, and distributed routing with low memory, 2017. ,
Planar graphs, negative weight edges, shortest paths, and near linear time, J. Comput. Syst. Sci, vol.72, issue.5, pp.868-889, 2006. ,
Compact navigation and distance oracles for graphs with small treewidth, Algorithmica, vol.69, issue.1, pp.92-116, 2014. ,
Stéphane Pérennes, and Ran Raz, J. Algorithms, vol.53, issue.1, pp.85-112, 2004. ,
Sublinear-space distance labeling using hubs, Distributed Computing -30th International Symposium, DISC 2016, pp.230-242, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01415064
Better tradeoffs for exact distance oracles in planar graphs, Proceedings of the Twenty-Ninth Annual ACM-SIAM Symposium on Discrete Algorithms, SODA 2018, pp.515-529, 2018. ,
Contraction hierarchies: Faster and simpler hierarchical routing in road networks, Experimental Algorithms, 7th International Workshop, vol.5038, pp.319-333, 2008. ,
Reach for A*: Efficient point-to-point shortest path algorithms, ALENEX, pp.129-143, 2006. ,
Reach-based routing: A new approach to shortest path algorithms optimized for road networks, ALENEX/ANALCO, pp.100-111, 2004. ,
A randomized parallel algorithm for single-source shortest paths, J. Algorithms, vol.25, issue.2, pp.205-220, 1997. ,
Beyond highway dimension: Small distance labels using tree skeletons, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01359084
Beyond highway dimension: Small distance labels using tree skeletons, Proceedings of the Twenty-Eighth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.1462-1478, 2017. ,
Graph spanners, Journal of Graph Theory, vol.13, issue.1, pp.99-116, 1989. ,
Randomized rounding: a technique for provably good algorithms and algorithmic proofs, Combinatorica, vol.7, issue.4, pp.365-374, 1987. ,
Time-work tradeoffs of the single-source shortest paths problem, J. Algorithms, vol.30, issue.1, pp.19-32, 1999. ,
Shortcutting planar digraphs, Combinatorics, Probability & Computing, vol.4, pp.287-315, 1995. ,
Parallel shortcutting of rooted trees, J. Algorithms, vol.23, issue.1, pp.139-159, 1997. ,
High-probability parallel transitive closure algorithms, SPAA, pp.200-209, 1990. ,
