Terahertz emission from laser-driven gas-plasmas: a plasmonic point of view
We investigate terahertz generation in two-color laser-induced gas plasmas. Resonances attributed to plasmonic effects are shown to broaden the emission spectra significantly, when electrons are excited along a direction where the plasma size is smaller than the plasma wavelength. We demonstrate that such resonances can be turned on and off by changing the polarization properties of elliptically-shaped driving laser-pulses. Both 3D Maxwell consistent simulations and experimental results confirm that a significant THz pulse shortening and spectral broadening can be achieved by exploiting the transverse driving laser-beam shape as an additional degree of freedom.
