Impact analysis-towards a framework for comparison, Software Maintenance, 1993. CSM-93, Proceedings ., Conference on, pp.292-301, 1993. ,
Supporting predictive change impact analysis: a control call graph based technique, 12th Asia-Pacific Software Engineering Conference (APSEC'05), p.9, 2005. ,
DOI : 10.1109/APSEC.2005.100
Computation of Static Execute After Relation with Applications to Software Maintenance, 2007 IEEE International Conference on Software Maintenance, pp.295-304, 2007. ,
DOI : 10.1109/ICSM.2007.4362642
Computing ripple effect for object oriented software, Quantitative Approaches in Object-Oriented Software Engineering (QAOOSE), 2006. ,
Incremental impact analysis for object-oriented software, 2004. ,
Computing ripple effect for software maintenance, Journal of Software Maintenance and Evolution: Research and Practice, vol.3, issue.2, 2001. ,
DOI : 10.1049/sej.1988.0003
Using coupling measurement for impact analysis in object-oriented systems, Software Maintenance , 1999.(ICSM'99) Proceedings. IEEE International Conference on, pp.475-482, 1999. ,
Ripples: tool for change in legacy software, Software Maintenance Proceedings. IEEE International Conference on, pp.230-239, 2001. ,
Refactoring, Proceedings of the 24th international conference on Software engineering , ICSE '02, 1999. ,
DOI : 10.1145/581441.581453
Tracker-a tool for change propagation in java Static execute after/before as a replacement of traditional software dependencies, Software Maintenance and Reengineering, 2003. Proceedings. Seventh European Conference on Software Maintenance IEEE International Conference on, pp.223-229, 2003. ,
The Emergence of Change at the Systems Engineering and Software Design Interface, 2008. ,
Change impact identification in object oriented software maintenance, Proceedings International Conference on Software Maintenance ICSM-94, pp.202-211, 1994. ,
DOI : 10.1109/ICSM.1994.336774
Algorithmic analysis of the impacts of changes to object-oriented software, Proceedings. 34th International Conference on Technology of Object-Oriented Languages and Systems, TOOLS 34, pp.61-70, 2000. ,
DOI : 10.1109/TOOLS.2000.868959
acm press the 12th international workshop and the 7th annual ercim workshop -szeged, hungary (2011.09.05-2011.09.06)] proceedings of the 12th international workshop and the 7th annual ercim workshop on principles on software evolution and software evolution -iwpse-evol '11 -a taxonomy for software change impact analysis, 2011. ,
A review of software change impact analysis, 2011. ,
-96 -algorithmic analysis of the impact of changes to object-oriented software, Proceedings of international conference on software maintenance icsm, 1996. ,
Evaluating impact analysis ? a case study, Empirical Software Engineering, vol.2, 1997. ,
Variable granularity for improving precision of impact analysis, 2009 IEEE 17th International Conference on Program Comprehension, pp.10-19, 2009. ,
DOI : 10.1109/ICPC.2009.5090023
URL : http://www.cs.wayne.edu/%7Esevere/publications/Petrenko.ICPC.2009.VariableGranularity.pdf
Improving Change Impact Analysis with a Tight Integrated Process and Tool, 2010 Seventh International Conference on Information Technology: New Generations, pp.956-961, 2010. ,
DOI : 10.1109/ITNG.2010.100
A model for change propagation based on graph rewriting, Proceedings International Conference on Software Maintenance, pp.84-91, 1997. ,
DOI : 10.1109/ICSM.1997.624234
URL : http://www.cs.wayne.edu/~vip/publications/Rajlich.ICSE.1997.ModelForChangePropagation.pdf
Chianti, ACM SIGPLAN Notices, vol.39, issue.10, pp.432-448, 2004. ,
DOI : 10.1145/1035292.1029012
Change impact analysis for objectoriented programs, Proceedings of the 2001 ACM SIGPLAN-SIGSOFT workshop on Program analysis for software tools and engineering, pp.46-53, 2001. ,
Comparison of different impact analysis methods and programmer's opinion, Proceedings of the 8th International Conference on the Principles and Practice of Programming in Java, PPPJ '10, pp.109-118, 2010. ,
DOI : 10.1145/1852761.1852777
A change impact dependency measure for predicting the maintainability of source code, Proceedings of the 28th Annual International Computer Software and Applications Conference, 2004. COMPSAC 2004., pp.22-23, 2004. ,
DOI : 10.1109/CMPSAC.2004.1342659
URL : http://csdl.computer.org/comp/proceedings/compsac/2004/2209/02/220920022.pdf
Ripple effect analysis of software maintenance COMPSAC'78. The IEEE Computer Society's Second International, Computer Software and Applications Conference, pp.60-65, 1978. ,
Change Impact Analysis for Generic Libraries, 2006 22nd IEEE International Conference on Software Maintenance, pp.35-44, 2006. ,
DOI : 10.1109/ICSM.2006.17
URL : http://www.osl.iu.edu/publications/prints/2006/zalewski_change_2006.pdf
