Solving Polynomial Systems Efficiently and Accurately - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We consider the problem of finding the isolated common roots of a set of polynomial functions defining a zero-dimensional ideal I in a ring R of polynomials over C. Normal form algorithms provide an algebraic approach to solve this problem. We use new characterizations of normal forms and describe accurate and efficient constructions that allow us to compute the algebra structure of R/I, and hence the solutions of I. We show how the resulting algorithms give accurate results in double precision arithmetic and compare with normal form algorithms using Groebner bases and homotopy solvers.
paper-hal.pdf (334.55 Ko) Télécharger le fichier
hal-01738695 , version 1 (21-03-2018)
hal-01738695 , version 2 (07-12-2018)
Bernard Mourrain, Simon Telen, Marc van Barel. Solving Polynomial Systems Efficiently and Accurately. 2018. ⟨hal-01738695v1⟩
560 Consultations
519 Téléchargements
