Joint Screening Tests for LASSO - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Angélique Drémeau
This paper focusses on " safe " screening techniques for the LASSO problem. Motivated by the need for low-complexity algorithms, we propose a new approach, dubbed " joint screening test " , allowing to screen a set of atoms by carrying out one single test. The approach is particularized to two different sets of atoms, respectively expressed as sphere and dome regions. After presenting the mathematical derivations of the tests, we elaborate on their relative effectiveness and discuss the practical use of such procedures.
Group_screening.pdf (415.15 Ko) Télécharger le fichier
hal-01739477 , version 1 (21-03-2018)
Cedric Herzet, Angélique Drémeau. Joint Screening Tests for LASSO. ICASSP 2018 - IEEE International Conference on Acoustic, Speech and Signal Processing, Apr 2018, Calgary, Canada. pp.4084-4088, ⟨10.1109/ICASSP.2018.8462530⟩. ⟨hal-01739477⟩
559 Consultations
114 Téléchargements
