Teaching a new trick to an old dog: Revisiting the quadratic programming formulation of sparse recovery using ADMM, Acoustics, Speech and Signal Processing (ICASSP), 2014 IEEE International Conference on, pp.1512-1516, 2014. ,
A new approach to variable selection in least squares problems, IMA Journal of Numerical Analysis, vol.20, issue.3, pp.389-403, 2000. ,
DOI : 10.1093/imanum/20.3.389
Least angle regression, The Annals of Statistics, vol.32, issue.2, pp.407-451, 2004. ,
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
Safe feature elimination in sparse supervised learning, 2010. ,
Learning sparse representations of high dimensional data on large scale dictionaries, Advances in Neural Information Processing Systems 24, J. Shawe-taylor, pp.900-908, 2011. ,
An ellipsoid based, two-stage screening test for BPDN, Signal Processing Conference (EUSIPCO), 2012 Proceedings of the 20th European, pp.654-658, 2012. ,
Lasso screening rules via dual polytope projection, Journal of Machine Learning Research, vol.16, issue.1, 2015. ,
Dynamic Screening: Accelerating First-Order Algorithms for the Lasso and Group-Lasso, IEEE Transactions on Signal Processing, vol.63, issue.19, pp.5121-5132, 2015. ,
DOI : 10.1109/TSP.2015.2447503
URL : https://hal.archives-ouvertes.fr/hal-01084986
Mind the duality gap: safer rules for the Lasso, ICML, 2015. ,
Safe screening tests for LASSO based on firmly non-expansiveness, 2016 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.4732-4736, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01260129
Fast Lasso screening tests based on correlations, Acoustics, Speech and Signal Processing (ICASSP), 2012 IEEE International Conference on, pp.2137-2140, 2012. ,
Screening tests for Lasso problems, 2014. ,
Towards a mathematical theory of super-resolution, Comm. Pure Appl. Math, vol.67, issue.6, pp.906-956, 2014. ,
Exact Support Recovery for Sparse Spikes Deconvolution, Foundations of Computational Mathematics, vol.15, issue.5, pp.1315-1355, 2015. ,
DOI : 10.1109/TIT.2012.2233859
URL : https://hal.archives-ouvertes.fr/hal-00839635
A mathematical introduction to compressive sensing., Applied and Numerical Harmonic Analysis, 2013. ,
DOI : 10.1007/978-0-8176-4948-7
Joint screening tests for Lasso, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01739477
Dynamic screening with approximate dictionaries, XXVIème colloque GRETSI, 2017. ,
