Abstract : Methods for achieving automatic speaker recognition may be classified into two
categories : pattern recognition based approaches that implicitly use interspeaker and intraspeaker
variability of speech and approaches which explicitly take into account the
sources of interspeaker and intraspeaker differences. The latter examine linguistic units
in order to extract features which are relevant for speaker characterization. The aim of the
present paper is precisely to study the relative effectiveness of the first three formants of
differents French vowels for speaker characterization.
As a part of a larger set of preselected acoustic and phonetic parameters, the seven
French vowels : / i /, / e /, / E /, / 0 /, / a /, / O /, / u /, with a neutral bilabial previous
context / p /, / b / and a lengthening subsequent context / R /, have been studied. For
that purpose, we have recorded and digitalized a set of seventeen sentences, uttered four
times by ten male speakers coming from the same region. In order to isolate the trigrams
/ p-vowel-R / and / b-vowel-R /, we have hand labeled the sentences according to strict
rules. We have then established an automatic method to determine very reliable values
of the three frequencies of the first formants of selected vowels. The retained frequencies
were then used to conduct a speaker identification experiment. Its aim was to identify an
unknown speaker from a group of ten known speakers by using his utterance of a given
vowel. To this end, a speaker was represented by a vector of one, two or three formant
frequencies or by a vector of one, two or three differences between two formant frequencies.
For each vowel and for each type of vector, i.e. each combination of formant frequencies,
three "relevance indicators" have been computed, i.e. the global speaker identification rate,
the sum of recognition ranks of every speaker and the ratio of intraspeaker to interspeaker
inertia. These indicators have been established for five kinds of weighting distance among
which a perceptual one.
In the first part of this paper, we present our methodology to evaluate the formant
frequencies of the vowels and we discuss the reliability of the results.
In the second one, we examine the relative effectiveness of every vowel for each
combination of formant frequencies by focusing on an interpretation of the results with
respect to speech production process. We also compare our results with those obtained
in normalization studies, in particular with the non-uniform female/male formant frequency
ratios (ki).
