Comparative Analysis of Culture Conditions for the Optimization of Carotenoid Production in Several Strains of the Picoeukaryote Ostreococcus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Marine drugs Année : 2018
Microalgae are promising sources for the sustainable production of compounds of interest for biotechnologies. Compared to higher plants, microalgae have a faster growth rate and can be grown in industrial photobioreactors. The microalgae biomass contains specific metabolites of high added value for biotechnology such as lipids, polysaccharides or carotenoid pigments. Studying carotenogenesis is important for deciphering the mechanisms of adaptation to stress tolerance as well as for biotechnological production. In recent years, the picoeukaryote Ostreococcus tauri has emerged as a model organism thanks to the development of powerful genetic tools. Several strains of Ostreococcus isolated from different environments have been characterized with respect to light response or iron requirement. We have compared the carotenoid contents and growth rates of strains of Ostreococcus (OTTH595, RCC802 and RCC809) under a wide range of light, salinity and temperature conditions. Carotenoid profiles and productivities varied in a strain-specific and stress-dependent manner. Our results also illustrate that phylogenetically related microalgal strains originating from different ecological niches present specific interests for the production of specific molecules under controlled culture conditions.
marinedrugs-16-00076.pdf (1.46 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-01740213 , version 1 (21-03-2018)
Paternité
Jean-Baptiste Guyon, Valérie Vergé, Philippe Schatt, Jean-Claude Lozano, Marion Liennard, et al.. Comparative Analysis of Culture Conditions for the Optimization of Carotenoid Production in Several Strains of the Picoeukaryote Ostreococcus. Marine drugs, 2018, 16 (3), pp.76. ⟨10.3390/md16030076⟩. ⟨hal-01740213⟩
96 Consultations
81 Téléchargements
