New interface
Conference papers
On Dissimilarity Measures at the Fuzzy Partition Level
Grégory Smits 1 Olivier Pivert 1 Toan Ngoc Duong
1 SHAMAN - Symbolic and Human-centric view of dAta MANagement
IRISA-D7 - GESTION DES DONNÉES ET DE LA CONNAISSANCE
Abstract : On the one hand, a user vocabulary is often used by soft-computing-based approaches to generate a linguistic and subjective description of numerical and categorical data. On the other hand, knowledge extraction strategies (as e.g. association rules discovery or clustering) may be applied to help the user understand the inner structure of the data. To apply knowledge extraction techniques on subjective and linguistic rewritings of the data, one first has to address the question of defining a dedicated distance metric. Many knowledge extraction techniques indeed rely on the use of a distance metric, whose properties have a strong impact on the relevance of the extracted knowledge. In this paper , we propose a measure that computes the dissimilarity between two items rewritten according to a user vocabulary.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01741885
Contributor : Grégory SMITS Connect in order to contact the contributor
Submitted on : Friday, March 23, 2018 - 3:03:15 PM
Last modification on : Monday, June 27, 2022 - 3:06:01 AM
Long-term archiving on: : Thursday, September 13, 2018 - 6:57:15 AM
File
dissimilarityMeasuresAtPartiti...
Identifiers
  • HAL Id : hal-01741885, version 1
Citation
Grégory Smits, Olivier Pivert, Toan Ngoc Duong. On Dissimilarity Measures at the Fuzzy Partition Level. 17th International Conference on Information Processing and Management of Uncertainty in Knowledge-Based Systems, Jun 2018, Cadiz, Spain. ⟨hal-01741885⟩
Share
Metrics
Record views
182
Files downloads
208
