Hypersonic Nonequilibrium Flows: Fundamentals and Recent Advances, Progress in Astronautics and Aeronautics, pp.329-342, 2015. ,
RTO-EN-AVT-008 -Measurement Techniques for High Enthalpy and Plasma Flows ,
Oxidation of ZrB2-SiC Ultrahigh-Temperature Ceramic Composites in Dissociated Air, Journal of Thermophysics and Heat Transfer, vol.16, issue.8, pp.267-278, 2009. ,
DOI : 10.2514/1.39974
Characterization of gas/surface interactions for ceramic matrix composites in high enthalpy, low pressure air flow, Materials Chemistry and Physics, vol.134, issue.2-3, pp.597-607, 2012. ,
DOI : 10.1016/j.matchemphys.2012.03.036
Temperature Jump Phenomenon During Plasmatron Testing of ZrB2-SiC Ultrahigh-Temperature Ceramics, Journal of Thermophysics and Heat Transfer, vol.67, issue.2, pp.559-572, 2012. ,
DOI : 10.1023/B:JMSC.0000041689.90456.af
Surface temperature jump beyond active oxidation of carbon/silicon carbide composites in extreme aerothermal conditions, Carbon, vol.71, pp.102-119, 2014. ,
DOI : 10.1016/j.carbon.2014.01.018
URL : https://hal.archives-ouvertes.fr/hal-01222599
Passive/active oxidation transition for CMC structural materials designed for the IXV vehicle re-entry phase, Journal of the European Ceramic Society, vol.35, issue.2, pp.487-502, 2015. ,
DOI : 10.1016/j.jeurceramsoc.2014.09.026
Recent catalysis measurements at IRS, Advances in Space Research, vol.56, issue.4, pp.742-765, 2015. ,
DOI : 10.1016/j.asr.2015.04.028
Local modeling of the aerodynamic heating of the blunt body surface in subsonic high-enthalpy air flow. Theory and experiment on a high-frequency plasmatron, Fluid Dynamics, vol.20, issue.2, pp.158-164, 2017. ,
DOI : 10.1201/9781439804667
Material response characterization of a low-density carbon composite ablator in high-enthalpy plasma flows, Journal of Materials Science, vol.38, issue.2, pp.4530-4543, 2014. ,
DOI : 10.2514/2.977
Uncertainty quantification of a graphite nitridation experiment using a Bayesian approach, Experimental Thermal and Fluid Science, vol.35, issue.8, pp.1588-1599, 2011. ,
DOI : 10.1016/j.expthermflusci.2011.07.010
Uncertainty quantification and robust predictive system analysis for high temperature kinetics of HCN/O 2 /Ar mixture, Chemical Physics, vol.475, pp.136-152, 2016. ,
DOI : 10.1016/j.chemphys.2016.05.026
Bayesian experimental design for the active nitridation of graphite by atomic nitrogen, Experimental Thermal and Fluid Science, vol.36, pp.178-193, 2012. ,
DOI : 10.1016/j.expthermflusci.2011.09.012
Conditions of simulation of stagnation point heat transfer from a high-enthalpy flow, Fluid Dynamics, vol.2, issue.1, pp.131-137, 1993. ,
DOI : 10.1007/BF01055676
The recombination of oxygen atoms at surfaces, Transactions of the Faraday Society, vol.54, pp.1323-1330, 1958. ,
DOI : 10.1039/tf9585401323
Measurements of the Diffusion Coefficient of Atomic Nitrogen in Molecular Nitrogen and the Catalytic Efficiency of Silver and Copper Oxide Surfaces, The Journal of Chemical Physics, vol.37, issue.4, pp.1295-1301, 1961. ,
DOI : 10.1139/v59-261
Effect of surface preparation and gas flow on nitrogen atom surface recombination, 1961. ,
Analysis of air arc-tunnel heat-transfer data, AIAA Journal, vol.173, issue.5, pp.945-948, 1964. ,
DOI : 10.1063/1.1731735
Heterogeneous recombination and heat transfer with dissociated nitrogen, 1964. ,
Recombination of oxygen atoms on oxide surfaces. Part 1.???Activation energies of recombination, Trans. Faraday Soc., vol.60, issue.0, pp.1272-1285, 1964. ,
DOI : 10.1039/TF9646001272
Diffusion Coefficient, The Journal of Chemical Physics, vol.8, issue.11, pp.4003-4006, 1965. ,
DOI : 10.1364/AO.4.000754
Recombination of atoms at surfaces An effusion method applied to oxygen atom recombination, Journal of Catalysis, vol.7, issue.4, pp.324-341, 1967. ,
DOI : 10.1016/0021-9517(67)90161-3
Stagnation-point convective heat transfer in frozen boundary layers., AIAA Journal, vol.27, issue.4, pp.619-626, 1968. ,
DOI : 10.1039/tf9646001272
Energy accommodation during oxygen atom recombination on metal surfaces, Transactions of the Faraday Society, vol.67, pp.198-211, 1971. ,
DOI : 10.1039/tf9716700198
Effect of surface catalytic activity on stagnation heat-transfer rates., AIAA Journal, vol.6, issue.3, pp.649-656, 1973. ,
DOI : 10.2514/3.2522
Thermal Energy Accommodation from Oxygen Atoms Recombination on Metallic Surfaces, Journal of Thermophysics and Heat Transfer, vol.12, issue.2, pp.206-213, 1998. ,
Comparison of Enthalpy Determination Methods for an Arc-Jet Facility, Journal of Thermophysics and Heat Transfer, vol.25, issue.2, pp.672-679, 2006. ,
DOI : 10.2514/1.6527
Oxygen Catalytic Recombination on Copper Oxide in Tertiary Gas Mixtures, Journal of Spacecraft and Rockets, vol.25, issue.2, pp.540-555, 2013. ,
DOI : 10.14429/dsj.40.4468
Investigation of Freestream Plasma Flow Produced by Inductively Coupled Plasma Wind Tunnel, Journal of Thermophysics and Heat Transfer, vol.34, issue.2, pp.381-393, 2014. ,
DOI : 10.2514/6.1985-247
Accurate and Efficient Modelling of High Temperature Nonequilibrium Air Flows, 2001. ,
Flight Extrapolation of Plasma Wind Tunnel Stagnation Region Flowfield, Journal of Thermophysics and Heat Transfer, vol.2, issue.2, pp.493-499, 2006. ,
DOI : 10.1007/978-3-642-58239-4_2
Cuts in Bayesian graphical models, Statistics and Computing, vol.30, issue.1, pp.37-43, 2014. ,
DOI : 10.1023/B:JOPA.0000012999.36063.4e
Applied dynamic programming, 2015. ,
DOI : 10.1515/9781400874651
Multi-element probabilistic collocation method in high dimensions, Journal of Computational Physics, vol.229, issue.5, pp.1536-1557, 2010. ,
DOI : 10.1016/j.jcp.2009.10.043
An Adaptive Metropolis Algorithm, Bernoulli, vol.7, issue.2, pp.223-242, 2001. ,
DOI : 10.2307/3318737
URL : http://www.geo.fmi.fi/~jtammine/ampure.ps.gz
A tutorial on adaptive MCMC, Statistics and Computing, vol.61, issue.3, pp.343-373, 2008. ,
DOI : 10.1007/978-3-642-55760-6
Markov Chains: Gibbs Fields, Monte Carlo Simulation, and Queues, Texts in Applied Mathematics, 2001. ,
DOI : 10.1007/978-1-4757-3124-8
The Markov chain Monte Carlo revolution, Bulletin of the American Mathematical Society, vol.46, issue.2, pp.179-205, 2009. ,
DOI : 10.1090/S0273-0979-08-01238-X
Equation of State Calculations by Fast Computing Machines, The Journal of Chemical Physics, vol.21, issue.6, p.1087, 1953. ,
DOI : 10.1063/1.1700747
