Cache-conscious scheduling of streaming applications, Proceedinbgs of the 24th ACM symposium on Parallelism in algorithms and architectures, SPAA '12, pp.236-245, 2012. ,
DOI : 10.1145/2312005.2312049
URL : http://dspace.mit.edu/bitstream/1721.1/90261/1/Leiserson_Cache-conscious.pdf
A heuristic for reducing fill-in in sparse matrix factorization, Proc. 6th SIAM Conf. Parallel Processing for Scientific Computing, pp.445-452, 1993. ,
PaToH: A Multilevel Hypergraph Partitioning Tool, Version 3.0, Bilkent University, Dept. Comp. Engineering, 1999. ,
Parallelism in structured Newton computations, Parallel Computing: Architectures, Algorithms and Applications, pp.295-302, 2007. ,
DOI : 10.1137/070701005
Fast (Structured) Newton Computations, SIAM Journal on Scientific Computing, vol.31, issue.2, pp.1175-1191, 2009. ,
Automatic Differentiation in MATLAB using ADMAT with Applications, 2016. ,
DOI : 10.1137/1.9781611974362
Acyclic multi-way partitioning of Boolean networks, Proceedings of the 31st annual conference on Design automation conference , DAC '94, pp.670-675, 1994. ,
DOI : 10.1145/196244.196609
The university of Florida sparse matrix collection, ACM Transactions on Mathematical Software, vol.38, issue.1, pp.1-1, 2011. ,
DOI : 10.1145/2049662.2049663
Benchmarking optimization software with performance profiles, Mathematical Programming, vol.91, issue.2, pp.201-213, 2002. ,
DOI : 10.1007/s101070100263
URL : http://arxiv.org/pdf/cs/0102001
On Characterizing the Data Access Complexity of Programs, ACM SIGPLAN Notices, vol.50, issue.1, pp.567-580, 2015. ,
DOI : 10.1016/j.jcss.2010.06.012
URL : https://hal.archives-ouvertes.fr/hal-01104556
Beyond reuse distance analysis, ACM Transactions on Architecture and Code Optimization, vol.10, issue.4, pp.1-5329, 2013. ,
DOI : 10.1145/2541228.2555309
URL : https://hal.archives-ouvertes.fr/hal-00920031
A linear-time heuristic for improving network partitions, Design Automation 19th Conference on, pp.175-181, 1982. ,
Computers and Intractability: A Guide to the Theory of NP-Completeness, 1979. ,
The Chaco user's guide, version 1.0, 1993. ,
Acyclic Partitioning of Large Directed Acyclic Graphs, 2017 17th IEEE/ACM International Symposium on Cluster, Cloud and Grid Computing (CCGRID), pp.371-380, 2017. ,
DOI : 10.1109/CCGRID.2017.101
URL : https://hal.archives-ouvertes.fr/hal-01672010
MeTiS: A Software Package for Partitioning Unstructured Graphs, Partitioning Meshes, and Computing Fill-Reducing Orderings of Sparse Matrices Version 4.0, 1998. ,
Optimal Sequential Partitions of Graphs, Journal of the ACM, vol.18, issue.1, pp.34-40, 1971. ,
DOI : 10.1145/321623.321627
An efficient heuristic procedure for partitioning graphs. The Bell System Technical Journal, pp.291-307, 1970. ,
DOI : 10.1002/j.1538-7305.1970.tb01770.x
Bohrium: A Virtual Machine Approach to Portable Parallelism, 2014 IEEE International Parallel & Distributed Processing Symposium Workshops, pp.312-321, 2014. ,
DOI : 10.1109/IPDPSW.2014.44
Fusion of Parallel Array Operations, Proceedings of the 2016 International Conference on Parallel Architectures and Compilation, PACT '16, pp.71-85, 2016. ,
DOI : 10.1109/MCSE.2011.37
Graph partitioning with acyclicity constraints ,
Evolutionary acyclic graph partitioning. CoRR, abs, 1709. ,
A branch-and-bound algorithm for the acyclic partitioning problem, Computers & Operations Research, vol.41, pp.174-184, 2014. ,
DOI : 10.1016/j.cor.2013.08.013
SCOTCH 5.1 User's Guide, Laboratoire Bordelais de Recherche en Informatique (LaBRI), 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00410327
Polybench: The polyhedral benchmark suite, p.2012 ,
Engineering Multilevel Graph Partitioning Algorithms, Algorithms ? ESA 2011: 19th Annual European Symposium, pp.469-480, 2011. ,
DOI : 10.1137/S1064827598337373
URL : http://algo2.iti.kit.edu/documents/kahip/engineering_multilevel.pdf
Multilevel Refinement for Combinatorial Optimisation Problems, Annals of Operations Research, vol.131, issue.1-4, pp.325-372, 2004. ,
DOI : 10.1023/B:ANOR.0000039525.80601.15
URL : http://staffweb.cms.gre.ac.uk/~c.walshaw/papers/fulltext/WalshawAoOR04.pdf
Clustering based acyclic multi-way partitioning, Proceedings of the 13th ACM Great Lakes Symposium on VLSI , GLSVLSI '03, pp.203-206, 2003. ,
DOI : 10.1145/764808.764860
URL : http://www.cse.cuhk.edu.hk/~fyyoung/paper/gvlsi03.pdf
