, Deep Learning with Differential Privacy, 2016.
, , 2011.
, Private Similarity Computation in Distributed Systems: from Cryptography to Differential Privacy, OPODIS, pp.357-377
Broadcast Gossip Algorithms for Consensus, IEEE Transactions on Signal Processing, vol.57, issue.7, pp.2748-2761, 2009. ,
Private Empirical Risk Minimization: Efficient Algorithms and Tight Error Bounds, FOCS, 2014. ,
Randomized gossip algorithms, IEEE/ACM Transactions on Networking, vol.14, issue.SI, pp.2508-2530, 2006. ,
Wearable continuous glucose monitoring sensors: A revolution in diabetes treatment, Electronics, vol.6, issue.3, 2017. ,
Differentially Private Empirical Risk Minimization, Journal of Machine Learning Research, vol.12, pp.1069-1109, 2011. ,
Gossip Dual Averaging for Decentralized Optimization of Pairwise Functions, ICML, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01329315
Semi-supervised multi-task learning of structured prediction models for web information extraction, CIKM, pp.957-966, 2011. ,
Privacy Aware Learning, NIPS, 2012. ,
, Differential Privacy. In ICALP, 2006.
Calibrating Noise to Sensitivity in Private Data Analysis, TCC, 2006. ,
The Algorithmic Foundations of Differential Privacy, Foundations and Trends in Theoretical Computer Science, vol.9, issue.3-4, pp.211-407, 2014. ,
Boosting and Differential Privacy, FOCS, 2010. ,
Regularized multi-task learning, KDD, 2004. ,
On Private Scalar Product Computation for Privacy-Preserving Data Mining, ICISC, 2004. ,
Learning privately from multiparty data, ICML, 2016. ,
Deep Models Under the GAN: Information Leakage from Collaborative Deep Learning, CCS, 2017. ,
, Differentially Private Distributed Optimization. ICDCN, 2015.
DOI : 10.1145/2684464.2684480
URL : http://arxiv.org/pdf/1401.2596
The Composition Theorem for Differential Privacy, ICML, 2015. ,
Extremal Mechanisms for Local Differential Privacy, Journal of Machine Learning Research, vol.17, pp.1-51, 2016. ,
Want to scale in centralized systems? Think P2P, Journal of Internet Services and Applications, vol.6, issue.1, p.12, 2015. ,
DOI : 10.1186/s13174-015-0029-1
URL : https://hal.archives-ouvertes.fr/hal-01199734
Can Decentralized Algorithms Outperform Centralized Algorithms? A Case Study for Decentralized Parallel Stochastic Gradient Descent, NIPS, 2017. ,
The Rademacher Complexity of Linear Transformation Classes, COLT, 2006. ,
The Limits of TwoParty Differential Privacy, FOCS, 2010. ,
Asynchronous Broadcast-Based Convex Optimization Over a Network, IEEE Transactions on Automatic Control, vol.56, issue.6, pp.1337-1351, 2011. ,
DOI : 10.1109/tac.2010.2079650
URL : http://www.ifp.illinois.edu/%7Eangelia/broadcast_revised_submit2.pdf
Distributed Subgradient Methods for Multi-Agent Optimization, IEEE Transactions on Automatic Control, vol.54, issue.1, pp.48-61, 2009. ,
DOI : 10.1109/tac.2008.2009515
Multiparty Differential Privacy via Aggregation of Locally Trained Classifiers, NIPS, 2010. ,
A Differentially Private Stochastic Gradient Descent Algorithm for Multiparty Classification, AISTATS, 2012. ,
Distributed Stochastic Subgradient Projection Algorithms for Convex Optimization, Journal of Optimization Theory and Applications, vol.147, issue.3, pp.516-545, 2010. ,
Privacy-Preserving Deep Learning, CCS, 2015. ,
DOI : 10.1109/allerton.2015.7447103
Stochastic gradient descent with differentially private updates, GlobalSIP, 2013. ,
DOI : 10.1109/globalsip.2013.6736861
URL : http://www.ece.rutgers.edu/%7Easarwate/pdfs/SongCS13sgd.pdf
, , 2017.
, Decentralized Collaborative Learning of Personalized Models over Networks, AISTATS
Distributed Alternating Direction Method of Multipliers, 2012. ,
On the O(1/k) Convergence of Asynchronous Distributed Alternating Direction Method of Multipliers, 2013. ,
, Coordinate descent algorithms. Mathematical Programming, vol.151, pp.3-34, 2015.
Large-Scale Parallel Collaborative Filtering for the Netflix Prize, AAIM, 2008. ,
