Constructing Inference-Proof Belief Mediators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Joachim Biskup
  • Fonction : Auteur
  • PersonId : 1010042
Cornelia Tadros
  • Fonction : Auteur
  • PersonId : 1029907
An information owner might interact with cooperation partners regarding its belief, which is derived from a collection of heterogeneous data sources and can be changed according to perceptions of the partners’ actions. While interacting, the information owner willingly shares some information with a cooperation partner but also might want to keep selected pieces of information confidential. This requirement should even be satisfied if the partner as an intelligent and only semi-honest attacker attempts to infer hidden information from accessible data, also employing background knowledge. For this problem of inference control, we outline and discuss a solution by means of a sophisticated mediator agent. Based on forming an integrated belief from the underlying data sources, the design adapts and combines known approaches to language-based information flow control and controlled interaction execution for logic-based information systems.
340025_1_En_12_Chapter.pdf (467.13 Ko) Télécharger le fichier
hal-01745830 , version 1 (28-03-2018)
Paternité
Joachim Biskup, Cornelia Tadros. Constructing Inference-Proof Belief Mediators. 29th IFIP Annual Conference on Data and Applications Security and Privacy (DBSEC), Jul 2015, Fairfax, VA, United States. pp.188-203, ⟨10.1007/978-3-319-20810-7_12⟩. ⟨hal-01745830⟩
55 Consultations
98 Téléchargements
