Van der Vorst, Templates for the Solution of Linear Systems: Building Blocks for Iterative Methods, 1994. ,
A Residual Replacement Strategy for Improving the Maximum Attainable Accuracy of $s$-Step Krylov Subspace Methods, SIAM Journal on Matrix Analysis and Applications, vol.35, issue.1, pp.22-43, 2014. ,
DOI : 10.1137/120893057
Avoiding Communication in Nonsymmetric Lanczos-Based Krylov Subspace Methods, SIAM Journal on Scientific Computing, vol.35, issue.5, pp.42-61, 2013. ,
DOI : 10.1137/120881191
Tich`Tich`y, and M. T?ma, On the numerical stability analysis of pipelined Krylov subspace methods, SIAM J. Sci. Comput ,
s-step iterative methods for symmetric linear systems, Journal of Computational and Applied Mathematics, vol.25, issue.2, pp.153-168, 1989. ,
DOI : 10.1016/0377-0427(89)90045-9
URL : https://doi.org/10.1016/0377-0427(89)90045-9
Block s-step Krylov iterative methods, Numerical Linear Algebra with Applications, vol.11, issue.2, pp.3-15, 2010. ,
DOI : 10.1137/1.9780898719611
Parallel iterative S-step methods for unsymmetric linear systems, Parallel Computing, vol.22, issue.5, pp.623-641, 1996. ,
DOI : 10.1016/0167-8191(96)00022-1
Reducing Communication Costs in the Conjugate Gradient Algorithm on Distributed Memory Multiprocessors, 1992. ,
DOI : 10.2172/10176473
A parallel variant of GMRES(m), Proceedings of the 13th IMACS World Congress on Computational and Applied Mathematics, pp.682-683, 1991. ,
Reducing the effect of global communication in GMRES(m) and CG on parallel distributed memory computers, Applied Numerical Mathematics, vol.18, issue.4, pp.441-459, 1995. ,
DOI : 10.1016/0168-9274(95)00079-A
Parallel numerical linear algebra, Acta Numerica, vol.10, pp.111-197, 1993. ,
DOI : 10.1007/BF01932738
URL : http://www.nsm.buffalo.edu/courses/mth667/cor501f03/LAPACnote.pdf
The International Exascale Software Project roadmap, The International Journal of High Performance Computing Applications, vol.25, issue.1, pp.25-28, 2011. ,
DOI : 10.1088/1742-6596/180/1/012045
URL : http://www.exascale.org/mediawiki/images/2/20/IESP-roadmap.pdf
Van der Vorst, Numerical Linear Algebra for High-Performance Computers, 1998. ,
Toward a New Metric for Ranking High Performance Computing Systems, 2013. ,
A new metric for ranking high-performance computing systems, National Science Review, vol.9, issue.1, 2015. ,
DOI : 10.1137/1.9780898718003
URL : https://academic.oup.com/nsr/article-pdf/3/1/30/7433907/nwv084.pdf
Scalable Non-blocking Preconditioned Conjugate Gradient Methods, SC16: International Conference for High Performance Computing, Networking, Storage and Analysis, pp.204-215, 2016. ,
DOI : 10.1109/SC.2016.17
Composite convergence bounds based on Chebyshev polynomials and finite precision conjugate gradient computations, Numerical Algorithms, vol.32, issue.156, pp.759-782, 2014. ,
DOI : 10.1002/sapm1953321243
Hiding Global Communication Latency in the GMRES Algorithm on Massively Parallel Machines, SIAM Journal on Scientific Computing, vol.35, issue.1, pp.48-71, 2013. ,
DOI : 10.1137/12086563X
Hiding global synchronization latency in the preconditioned Conjugate Gradient algorithm, Parallel Computing, vol.40, issue.7, pp.224-238, 2014. ,
DOI : 10.1016/j.parco.2013.06.001
Behavior of slightly perturbed Lanczos and conjugate-gradient recurrences, Linear Algebra and its Applications, vol.113, pp.7-63, 1989. ,
DOI : 10.1016/0024-3795(89)90285-1
Estimating the Attainable Accuracy of Recursively Computed Residual Methods, SIAM Journal on Matrix Analysis and Applications, vol.18, issue.3, pp.535-551, 1997. ,
DOI : 10.1137/S0895479895284944
Iterative Methods for Solving Linear Systems, 1997. ,
DOI : 10.1137/1.9781611970937
Predicting the Behavior of Finite Precision Lanczos and Conjugate Gradient Computations, SIAM Journal on Matrix Analysis and Applications, vol.13, issue.1, pp.121-137, 1992. ,
DOI : 10.1137/0613011
Accuracy of Two Three-term and Three Two-term Recurrences for Krylov Space Solvers, SIAM Journal on Matrix Analysis and Applications, vol.22, issue.1, pp.213-229, 2000. ,
DOI : 10.1137/S0895479897331862
Finding Structure with Randomness: Probabilistic Algorithms for Constructing Approximate Matrix Decompositions, SIAM Review, vol.53, issue.2, pp.217-288, 2011. ,
DOI : 10.1137/090771806
URL : http://www.acm.caltech.edu/%7Ejtropp/papers/HMT10-Finding-Structure-preprint.pdf
Methods of conjugate gradients for solving linear systems, Journal of Research of the National Bureau of Standards, vol.49, issue.6, pp.409-436, 1952. ,
DOI : 10.6028/jres.049.044
Accuracy and Stability of Numerical Algorithms, 2002. ,
DOI : 10.1137/1.9780898718027
Krylov Subspace Methods: Principles and Analysis ,
DOI : 10.1093/acprof:oso/9780199655410.001.0001
Computer Solution of Large Linear Systems, 1999. ,
The Lanczos and conjugate gradient algorithms in finite precision arithmetic, Acta Numerica, vol.15, pp.471-542, 2006. ,
DOI : 10.1017/S096249290626001X
On the convergence rate of the conjugate gradients in presence of rounding errors, Numerische Mathematik, vol.48, issue.156, pp.301-317, 1993. ,
DOI : 10.1007/BF01385754
The Computation of Eigenvalues and Eigenvectors of Very Large Sparse Matrices, 1971. ,
Computational Variants of the Lanczos Method for the Eigenproblem, IMA Journal of Applied Mathematics, vol.10, issue.3, pp.373-381, 1972. ,
DOI : 10.1093/imamat/10.3.373
Error Analysis of the Lanczos Algorithm for Tridiagonalizing a Symmetric Matrix, IMA Journal of Applied Mathematics, vol.18, issue.3, pp.341-349, 1976. ,
DOI : 10.1093/imamat/18.3.341
Accuracy and effectiveness of the Lanczos algorithm for the symmetric eigenproblem, Linear Algebra and its Applications, vol.34, pp.235-258, 1980. ,
DOI : 10.1016/0024-3795(80)90167-6
Iterative Methods for Sparse Linear Systems, 2003. ,
Zuverl????lich berechnete Residuen in hybriden Bi-CG Verfahren, Computing, vol.15, issue.2, pp.56-141, 1996. ,
DOI : 10.6028/jres.049.006
BiCGstab(l) and other hybrid Bi-CG methods, Numerical Algorithms, vol.15, issue.1, pp.75-109, 1994. ,
DOI : 10.1137/0613050
URL : http://www.math.ruu.nl/people/sleijpen/Reprints/SVF94.pdf
Differences in the Effects of Rounding Errors in Krylov Solvers for Symmetric Indefinite Linear Systems, SIAM Journal on Matrix Analysis and Applications, vol.22, issue.3, pp.726-751, 2001. ,
DOI : 10.1137/S0895479897323087
Relaxationsmethoden bester Strategie zur L??sung linearer Gleichungssysteme, Commentarii Mathematici Helvetici, vol.29, issue.1, pp.157-179, 1955. ,
DOI : 10.1007/BF02564277
Effectivity and optimizing of algorithms and programs on the host-computer/array-processor system, Parallel Computing, vol.4, issue.2, pp.189-207, 1987. ,
DOI : 10.1016/0167-8191(87)90051-2
Tich`y, On error estimation in the Conjugate Gradient method and why it works in finite precision computations, Electron. Trans. Numer. Anal, vol.13, pp.56-80, 2002. ,
Error Estimation in Preconditioned Conjugate Gradients, BIT Numerical Mathematics, vol.45, issue.4, pp.789-817, 2005. ,
DOI : 10.1007/s10543-005-0032-1
Analysis of the finite precision bi-conjugate gradient algorithm for nonsymmetric linear systems, Mathematics of Computation, vol.69, issue.232, pp.1559-1575, 2000. ,
DOI : 10.1090/S0025-5718-99-01171-0
Residual Replacement Strategies for Krylov Subspace Iterative Methods for the Convergence of True Residuals, SIAM Journal on Scientific Computing, vol.22, issue.3, pp.835-852, 2000. ,
DOI : 10.1137/S1064827599353865
Rounding Errors in Algebraic Processes, Courier Corporation, 1994. ,
