J. Richard, Time-delay systems: an overview of some recent advances and open problems, Automatica, vol.39, issue.10, pp.1667-1694, 2003.
DOI : 10.1016/S0005-1098(03)00167-5
L. Bushnell, Networks and control [Guest Editorial], IEEE Control Systems, vol.21, issue.1, pp.22-99
DOI : 10.1109/MCS.2001.898789
C. Hua and X. P. Liu, EDITORIAL, International Journal of Bifurcation and Chaos, vol.22, issue.05, pp.925-932, 2010.
DOI : 10.1142/S021812741202004X
E. Fridman, Tutorial on Lyapunov-based methods for time-delay systems, European Journal of Control, vol.20, issue.6, pp.271-283, 2014.
DOI : 10.1016/j.ejcon.2014.10.001
T. Slama, A. Trevisani, D. Aubry, R. Oboe, and F. Kratz, Experimental Analysis of an Internet-Based Bilateral Teleoperation System With Motion and Force Scaling Using a Model Predictive Controller, IEEE Transactions on Industrial Electronics, vol.55, issue.9, pp.3290-3299, 2008.
DOI : 10.1109/TIE.2008.928120
S. Hirche and M. Buss, Human-Oriented Control for Haptic Teleoperation, Proceedings of the IEEE, pp.623-647, 2012.
DOI : 10.1109/JPROC.2011.2175150
URL : http://ieeexplore.ieee.org:80/stamp/stamp.jsp?tp=&arnumber=6127891
E. Fridman, Introduction to Time-Delay Systems: Analysis and Control, 2014.
DOI : 10.1007/978-3-319-09393-2
. Yu, V. Mikheev, E. Sobolev, and . Fridman, Asymptotic analysis of digital control systems, Autom. Remote Control, vol.49, pp.1175-1180, 1988.
A. Isidori, Nonlinear Control Systems II, 1999.
DOI : 10.1007/978-1-4471-0549-7
A. Filippov, Differential equations with discontinuous right-hand side, 1988.
DOI : 10.1090/trans2/042/13
E. Cruz-zavala, J. A. Moreno, and L. Fridman, Uniform Second-Order Sliding Mode Observer for mechanical systems, 2010 11th International Workshop on Variable Structure Systems (VSS), 2010.
DOI : 10.1109/VSS.2010.5544656
M. Livne and A. Levant, Accuracy of disturbed homogeneous sliding modes, the 13th Scientific Workshop VSS13, 2014.
A. Levant, Homogeneity of differential inclusions: Application to sliding modes, 2015 European Control Conference (ECC), pp.2458-2463, 2015.
DOI : 10.1109/ECC.2015.7330907
A. Polyakov, D. Efimov, and W. Perruquetti, Robust stabilization of MIMO systems in finite/fixed time, International Journal of Robust and Nonlinear Control, vol.42, issue.10, 2016.
DOI : 10.1201/9781420065619
URL : https://hal.archives-ouvertes.fr/hal-01160052
Y. Orlov, Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2004.
DOI : 10.1137/S0363012903425593
V. I. Korobov, A general approach to synthesis problem, Doklady Academii Nauk SSSR, vol.248, pp.1051-1063, 1979.
J. Adamy and A. Flemming, Soft variable-structure controls: a survey, Automatica, vol.40, issue.11, pp.1821-1844, 2004.
DOI : 10.1016/j.automatica.2004.05.017
D. Efimov and W. Perruquetti, HOMOGENEITY FOR TIME-DELAY SYSTEMS, Proc. IFAC WC 2011, 2011.
DOI : 10.3182/20110828-6-IT-1002.03195
URL : https://hal.archives-ouvertes.fr/hal-00628890
A. Bacciotti and L. Rosier, Lyapunov Functions and Stability in Control Theory, 2005.
D. Efimov, A. Polyakov, W. Perruquetti, and J. Richard, Weighted Homogeneity for Time-Delay Systems: Finite-Time and Independent of Delay Stability, IEEE Transactions on Automatic Control, vol.61, issue.1, pp.210-215, 2016.
DOI : 10.1109/TAC.2015.2427671
URL : https://hal.archives-ouvertes.fr/hal-01145321
V. B. Kolmanovsky and V. R. Nosov, Stability of functional differential equations. CA: Academic, 1986.
K. Zimenko, D. Efimov, A. Polyakov, and W. Perruquetti, A note on delay robustness for homogeneous systems with negative degree, Automatica, vol.79, pp.178-184, 2017.
DOI : 10.1016/j.automatica.2017.01.036
URL : https://hal.archives-ouvertes.fr/hal-01419131
A. Polyakov, D. Efimov, and W. Perruquetti, Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, pp.332-340, 2015.
DOI : 10.1016/j.automatica.2014.10.082
URL : https://hal.archives-ouvertes.fr/hal-01098099
S. Bhat and D. Bernstein, Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000.
DOI : 10.1137/S0363012997321358
S. Laghrouche, M. Harmouche, and Y. Chitour, Stabilization of perturbed integrator chains using Lyapunov-Based Homogeneous Controllers, International Journal of Control, pp.1-10, 2016.
