HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
On Necessary and Sufficient Conditions for Fixed-Time Stability of Continuous Autonomous Systems
Abstract : Necessary and sufficient conditions for fixed-time stability of continuous autonomous system are given. Continuity of the settling-time function is considered and a characterization of fixed-time stability with continuous settling-time function is presented. Further refinements of these conditions that allow more constructive calculations are provided. Several academic examples are provided to illustrate the theoretical results.
Document type :
Conference papers
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01755079
Contributor : Denis Efimov Connect in order to contact the contributor
Submitted on : Friday, March 30, 2018 - 1:05:40 PM
Last modification on : Friday, February 4, 2022 - 3:11:19 AM
File
ECC18_Paco_A.pdf
Identifiers
  • HAL Id : hal-01755079, version 1
Collections
Citation
Francisco Lopez-Ramirez, Denis Efimov, Andrey Polyakov, Wilfrid Perruquetti. On Necessary and Sufficient Conditions for Fixed-Time Stability of Continuous Autonomous Systems. Proc. 17th European Control Conference (ECC), Jun 2018, Limassol, Cyprus. ⟨hal-01755079⟩
Share
Metrics
Record views
246
Files downloads
583
