New interface
Preprints, Working Papers, ...
3D Consistent Biventricular Myocardial Segmentation Using Deep Learning for Mesh Generation
Abstract : We present a novel automated method to segment the my-ocardium of both left and right ventricles in MRI volumes. The segmen-tation is consistent in 3D across the slices such that it can be directly used for mesh generation. Two specific neural networks with multi-scale coarse-to-fine prediction structure are proposed to cope with the small training dataset and trained using an original loss function. The former segments a slice in the middle of the volume. Then the latter iteratively propagates the slice segmentations towards the base and the apex, in a spatially consistent way. We perform 5-fold cross-validation on the 15 cases from STACOM to validate the method. For training, we use real cases and their synthetic variants generated by combining motion simulation and image synthesis. Accurate and consistent testing results are obtained.
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-01755317
Contributor : Qiao Zheng Connect in order to contact the contributor
Submitted on : Friday, March 30, 2018 - 3:32:50 PM
Last modification on : Saturday, June 25, 2022 - 11:29:50 PM
File
miccai2017paper1_version2.pdf
Identifiers
  • HAL Id : hal-01755317, version 1
  • ARXIV : 1803.11080
Collections
Citation
Qiao Zheng, Hervé Delingette, Nicolas Duchateau, Nicholas Ayache. 3D Consistent Biventricular Myocardial Segmentation Using Deep Learning for Mesh Generation. {date}. ⟨hal-01755317⟩
Share
Metrics
Record views
230
Files downloads
120
