A Heuristic Quasi-Polynomial Algorithm for Discrete Logarithm in Finite Fields of Small Characteristic, Advances in Cryptology? EUROCRYPT 2014, pp.1-16, 2014. ,
DOI : 10.1007/978-3-642-55220-5_1
On the inherent intractability of certain coding problems, IEEE Transactions on Information Theory, vol.24, issue.3, pp.384-386, 1978. ,
The cryptographic security of the syndrom decoding problem for rank distance codes, Advances in Cryptology-ASIACRYPT'96, pp.368-381, 1996. ,
Low Rank Parity Check codes and their application to cryptography, The preproceedings of Workshop on Codes and Cryptography (WCC), pp.167-179, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00913719
On the complexity of the Rank Syndrome Decoding problem. arXiv preprint, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01280904
The Rank of Circulant Matrices, Journal of the London Mathematical Society, vol.1, issue.4, pp.445-460, 1956. ,
DOI : 10.1112/jlms/s1-31.4.445
Finite Fields, 1997. ,
DOI : 10.1017/CBO9780511525926
A Public-Key Cryptosystem Based On Algebraic Coding Theory, DSN Progress Report, vol.42, issue.44, pp.114-116, 1978. ,
New techniques for decoding codes in the rank metric and its cryptography applications. Problems of Information Transmission, pp.237-246, 2002. ,
On the hardness of the decoding and the minimum distance problems for rank codes. arXiv preprint arXiv :1404, 2014. ,
On cellular code and their cryptographic applications ,
Finding the permutation between equivalent linear codes: the support splitting algorithm, IEEE Transactions on Information Theory, vol.46, issue.4, pp.1193-1203, 2000. ,
DOI : 10.1109/18.850662
