Why Channel Hopping Makes Sense, even with IEEE802.15.4 OFDM at 2.4 GHz - Archive ouverte HAL Access content directly
Conference Papers Year :
(1) , (1) , (2) , (1)
1
2
Since its 2015 revision, IEEE802.15.4 now supports the OFDM physical layer at 2.4 GHz, on top of the popular O-QPSK modulation. Chips capable of both O-QPSK and OFDM are currently available. The question now is whether OFDM is relevant for low-power wireless mesh networking; given its prevalence in 4G cellular, it could be a game-changer. We start by collecting a comprehensive connectivity dataset, 141,587,000 data points, continuously over 21 days. We then show, in an entirely counter-intuitive manner, that OFDM alone is not enough to cope with external interference and multi-path fading, and we recommend combining OFDM with channel hopping at the link layer. In the presence of WiFi interference, we further recommend using OFDM option 1 MCS3, a fast 800 kbps mode, which does not use frequency repetition, even though the latter is meant to increase frequency diversity.
18_munoz18channel.pdf (7.54 Mo) Télécharger le fichier
Dates and versions
hal-01756523 , version 1 (03-01-2019)
Identifiers
  • HAL Id : hal-01756523 , version 1
Cite
Jonathan Munoz, Paul Mühlethaler, Xavier Vilajosana, Thomas Watteyne. Why Channel Hopping Makes Sense, even with IEEE802.15.4 OFDM at 2.4 GHz. Global IoT Summit (GIoTS), Jun 2018, Bilbao, Spain. ⟨hal-01756523⟩
Collections
INRIA INRIA2
109 View
322 Download
Share
