Abstract : Heterogeneous search engines differ in the algorithms they use and the domains they cover, thus there is no single search engine that performs best in every circumstance. In order to obtain optimal search results, it often makes sense to use more than one search engine. However, appropriately merging results from different engines is challenging, i.e. combining results in such a way that they reflect the ranking of results the user would choose. In this paper, we propose an effective way to achieve this for web services search which can be extended to cloud services and be applied to big data. In contrast to “classical” search processed by conventional text-based search engines, a more elaborated search request is needed here. In addition to the result merging, we therefore present a method to create a structured request for this specific task. The evaluation of our proposed solution shows that it is satisfying in terms of both result quality and performance.
https://hal.inria.fr/hal-01757570 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, April 3, 2018 - 5:20:17 PM Last modification on : Monday, November 29, 2021 - 3:39:02 PM
