A Heterogeneous Approach for Developing Applications with FIWARE GEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Simone Di Cola
  • Fonction : Auteur
  • PersonId : 1030147
Cuong Tran
  • Fonction : Auteur
  • PersonId : 1030148
Kung-Kiu Lau
  • Fonction : Auteur
  • PersonId : 982373
The European Commission funded FIWARE project aims to support the development of a European cloud, and a rich catalogue of generic components called Generic Enablers (GEs). However, the lack of an efficient approach and tool for developing applications using GEs hinders their adoption. This paper tries to fill this gap by proposing an approach based on a component model, along with its related tool, that allows heterogeneous composition of GEs and non-GE components. The approach is validated with a case study where a content delivery application is developed.
370579_1_En_5_Chapter.pdf (2.51 Mo) Télécharger le fichier
hal-01757575 , version 1 (03-04-2018)
Paternité
Simone Di Cola, Cuong Tran, Kung-Kiu Lau, Antonio Celesti, Maria Fazio. A Heterogeneous Approach for Developing Applications with FIWARE GEs. 4th European Conference on Service-Oriented and Cloud Computing (ESOCC), Sep 2015, Taormina, Italy. pp.65-79, ⟨10.1007/978-3-319-24072-5_5⟩. ⟨hal-01757575⟩
273 Consultations
135 Téléchargements
