Formal Verification of Service Level Agreements Through Distributed Monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we introduce a formal model of the availability, budget compliance and sustainability of istributed services, where service sustainability is a new concept which arises as the composition of service availability and budget compliance. The model formalizes a distributed platform for monitoring the above service characteristics in terms of a parallel composition of task automata, where dynamically generated tasks model asynchronous events with deadlines. The main result of this paper is a formal model to optimize and reason about service characteristics through monitoring. In particular, we use schedulability analysis of the underlying timed automata to optimize and guarantee service sustainability.
370579_1_En_9_Chapter.pdf (394.97 Ko) Télécharger le fichier
hal-01757576 , version 1 (03-04-2018)
Paternité
Behrooz Nobakht, Stijn De Gouw, Frank Boer. Formal Verification of Service Level Agreements Through Distributed Monitoring. 4th European Conference on Service-Oriented and Cloud Computing (ESOCC), Sep 2015, Taormina, Italy. pp.125-140, ⟨10.1007/978-3-319-24072-5_9⟩. ⟨hal-01757576⟩
60 Consultations
136 Téléchargements
