On Local LTI Model Coherence for LPV Interpolation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Lennart Ljung
  • Fonction : Auteur
  • PersonId : 973111
In the local approach to linear parameter varying (LPV) system identification, it is widely acknowledged that locally estimated linear state-space models should be made coherent before being interpolated, but the accurate meaning of the term " coherent " or " coherence " is rarely defined. The purpose of this paper is to analyze the relevance of two existing definitions and to point out the consequence of this analysis on the practice of LPV system identification.
Automatique
coherence_hal.pdf (252.77 Ko) Télécharger le fichier
hal-01758337 , version 1 (04-04-2018)
hal-01758337 , version 2 (21-11-2019)
  • HAL Id : hal-01758337 , version 1
Qinghua Zhang, Lennart Ljung, Rik Pintelon. On Local LTI Model Coherence for LPV Interpolation. 2018. ⟨hal-01758337v1⟩
280 Consultations
340 Téléchargements
