Computing Stieltjes constants using complex integration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2019
The generalized Stieltjes constants $\gamma_n(v)$ are, up to a simple scaling factor, the Laurent series coefficients of the Hurwitz zeta function $\zeta(s,v)$ about its unique pole $s = 1$. In this work, we devise an efficient algorithm to compute these constants to arbitrary precision with rigorous error bounds, for the first time achieving this with low complexity with respect to the order~$n$. Our computations are based on an integral representation with a hyperbolic kernel that decays exponentially fast. The algorithm consists of locating an approximate steepest descent contour and then evaluating the integral numerically in ball arithmetic using the Petras algorithm with a Taylor expansion for bounds near the saddle point. An implementation is provided in the Arb library. We can, for example, compute $\gamma_n(1)$ to 1000 digits in a minute for any $n$ up to $n=10^{100}$. We also provide other interesting integral representations for $\gamma_n(v)$, $\zeta(s)$, $\zeta(s,v)$, some polygamma functions and the Lerch transcendent.
stieltjes.pdf (379.94 Ko) Télécharger le fichier
hal-01758620 , version 1 (04-04-2018)
hal-01758620 , version 2 (30-05-2018)
hal-01758620 , version 3 (11-08-2018)
Fredrik Johansson, Iaroslav V Blagouchine. Computing Stieltjes constants using complex integration. Mathematics of Computation, 2019, 88 (318), ⟨10.1090/mcom/3401⟩. ⟨hal-01758620v3⟩
495 Consultations
504 Téléchargements
