Adiabatic ensemble control of a continuum of quantum systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
In this article we discuss how to control a parameter-dependent family of quantum systems. Our technique is based on adiabatic approximation theory and on the presence of curves of conical eigenvalue intersections of the controlled Hamiltonian. As particular cases, we recover chirped pulses for two-level quantum systems and counter-intuitive solutions for three-level stimulated Raman adiabatic passage (STIRAP). The proposed technique works for systems evolving both in finite-dimensional and infinite-dimensional Hilbert spaces. We show that the assumptions guaranteeing ensemble controllability are structurally stable with respect to perturbations of the parametrized family of systems.
simultaneo-hal.pdf (1.62 Mo) Télécharger le fichier
hal-01759830 , version 1 (05-04-2018)
hal-01759830 , version 2 (19-10-2018)
  • HAL Id : hal-01759830 , version 1
Nicolas Augier, Ugo Boscain, Mario Sigalotti. Adiabatic ensemble control of a continuum of quantum systems. 2018. ⟨hal-01759830v1⟩
Collections
ENS-CACHAN
663 Consultations
740 Téléchargements
