Transversal mappings and flows. An appendix by Al Kelley, 1967. ,
Controllability of the Schrödinger equation via intersection of eigenvalues, Proceedings of the 44th IEEE Conference on Decision and Control, pp.1080-1085, 2005. ,
Ensemble controllability by Lie algebraic methods, ESAIM Control Optim. Calc. Var, vol.22, issue.4, pp.921-938, 2016. ,
Modeling and control of quantum systems: an introduction, IEEE Trans. Automat. Control, vol.57, issue.8, pp.1898-1917, 2012. ,
Controllability issues for continuous-spectrum systems and ensemble controllability of Bloch equations, Comm. Math. Phys, vol.296, issue.2, pp.525-557, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00475751
Ensemble controllability and discrimination of perturbed bilinear control systems on connected, simple, compact Lie groups, Eur. J. Control, vol.22, pp.23-29, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00866229
Finite controllability of infinite-dimensional quantum systems, IEEE Transactions on Automatic Control, vol.55, issue.8, pp.1797-1805, 2010. ,
A weak spectral condition for the controllability of the bilinear Schrödinger equation with application to the control of a rotating planar molecule, Comm. Math. Phys, vol.311, issue.2, pp.423-455, 2012. ,
Adiabatic control of the Schroedinger equation via conical intersections of the eigenvalues, IEEE Trans. Automat. Control, vol.57, issue.8, pp.1970-1983, 2012. ,
Approximate controllability, exact controllability, and conical eigenvalue intersections for quantum mechanical systems, Comm. Math. Phys, vol.333, issue.3, pp.1225-1239, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00869706
On the control of spin-boson systems, J. Math. Phys, vol.56, issue.9, p.15, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00923624
Ensemble control of parameter-dependent quantum systems by adiabatic evolution, Proceedings of the 56th IEEE Conference on Decision and Control, 2017. ,
Control of quantum phenomena: past, present and future, New Journal of Physics, vol.12, issue.7, p.75008, 2010. ,
Efficient molecular dissociation by a chirped ultrashort infrared laser pulse, Phys. Rev. Lett, vol.65, pp.2355-2358, 1990. ,
Sampling-based learning control of inhomogeneous quantum ensembles, Physical Review A, vol.89, issue.2, p.23402, 2014. ,
Approximate controllability by adiabatic methods of the Schrödinger equation with nonlinear Hamiltonian, Proceedings of the IEEE 54th Annual Conference on Decision and Control (CDC), pp.7771-7776, 2015. ,
Asymptotic ensemble stabilizability of the Bloch equation, Systems Control Lett, vol.113, pp.36-44, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01504321
Approximate controllability via adiabatic techniques for the three-inputs controlled Schrödinger equation, SIAM J. Control Optim, vol.55, issue.6, pp.4202-4226, 2017. ,
Introduction to quantum control and dynamics, Applied Mathematics and Nonlinear Science Series, 2008. ,
Ensemble controllability of bilinear systems, Oberwolfach Reports, vol.9, issue.1, pp.674-676, 2012. ,
Quantum control theory and applications: a survey, IET Control Theory & Applications, vol.4, issue.12, pp.2651-2671, 2010. ,
Population transfer between molecular vibrational levels by stimulated Raman scattering with partially overlapping laser fields. a new concept and experimental results, The Journal of Chemical Physics, vol.92, issue.9, pp.5363-5376, 1990. ,
On the codimension one motion planning problem, J. Dyn. Control Syst, vol.11, issue.1, pp.73-89, 2005. ,
Training Schrödinger's cat: quantum optimal control. Strategic report on current status, visions and goals for research in Europe, European Physical Journal D, vol.69, p.279, 2015. ,
Stratified Morse theory, Ergebnisse der Mathematik und ihrer Grenzgebiete, vol.14, issue.3 ,
, , 1988.
Uniform ensemble controllability for one-parameter families of time-invariant linear systems, Systems Control Lett, vol.71, pp.69-77, 2014. ,
Bounds for the adiabatic approximation with applications to quantum computation, Journal of Mathematical Physics, vol.48, issue.10, p.102111, 2007. ,
Perturbation theory for linear operators, Classics in Mathematics, 1995. ,
Controlling Several Atoms in a Cavity, New J. Phys, vol.16, p.65010, 2014. ,
Arbitrary control of a quantum electro-magnetic field, Phys. Rev. Lett, vol.76, issue.7, pp.1055-1058, 1996. ,
Adiabatic passage and ensemble control of quantum systems, Journal of Physics B, vol.44, issue.15, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00638429
Ensemble control of finite-dimensional time-varying linear systems, IEEE Trans. Automat. Control, vol.56, issue.2, pp.345-357, 2011. ,
Control of inhomogeneous quantum ensembles, Phys. Rev. A, vol.73, p.30302, 2006. ,
Ensemble control of Bloch equations, IEEE Trans. Automat. Control, vol.54, issue.3, pp.528-536, 2009. ,
Ensemble control of time-invariant linear systems with linear parameter variation, IEEE Trans. Automat. Control, issue.10, pp.2808-2820, 2016. ,
Approximate controllability of the two trapped ions system, Quantum Information Processing, vol.14, pp.2397-2418, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01092509
Methods of modern mathematical physics. IV. Analysis of operators, 1978. ,
Perturbation theory of eigenvalue problems, 1969. ,
Complete transfer of populations from a single state to a preselected superposition of states using piecewise adiabatic passage: Theory, Physical Review A, vol.79, issue.2, p.23422, 2009. ,
The theory of coherent atomic excitation, vol.1, 1990. ,
The theory of coherent atomic excitation, vol.2, 1990. ,
Application of optimal control theory to the design of broadband excitation pulses for high-resolution NMR, Journal of Magnetic Resonance, vol.163, issue.1, pp.8-15, 2003. ,
Adiabatic perturbation theory in quantum dynamics, Lecture Notes in Mathematics, vol.1821, 2003. ,
¨ Uberdas Verhalten von Eigenwerten bei Adiabatischen Prozessen, Z. Phys, vol.30, pp.467-470, 1929. ,
Controllability of the coupled spin-1 2 harmonic oscillator system, Physical Review A, vol.75, p.52331, 2007. ,
