On a routing problem, Quarterly of Applied Mathematics, vol.16, issue.1, pp.87-90, 1958. ,
DOI : 10.1090/qam/102435
A quantitative study of irregular programs on GPUs, 2012 IEEE International Symposium on Workload Characterization (IISWC), pp.141-151, 2012. ,
DOI : 10.1109/IISWC.2012.6402918
An Efficient Implementation of the Bellman-Ford Algorithm for Kepler GPU Architectures, IEEE Transactions on Parallel and Distributed Systems, vol.27, issue.8, pp.2222-2233, 2016. ,
DOI : 10.1109/TPDS.2015.2485994
Improving Global Performance on GPU for Algorithms with Main Loop Containing a Reduction Operation: Case of Dijkstra???s Algorithm, Journal of Computer and Communications, vol.03, issue.08, p.41, 2015. ,
DOI : 10.4236/jcc.2015.38005
A parallelization of Dijkstra's shortest path algorithm, International Symposium on Mathematical Foundations of Computer Science, pp.722-731, 1998. ,
DOI : 10.1007/BFb0055823
Work-Efficient Parallel GPU Methods for Single-Source Shortest Paths, 2014 IEEE 28th International Parallel and Distributed Processing Symposium, pp.349-359, 2014. ,
DOI : 10.1109/IPDPS.2014.45
A note on two problems in connexion with graphs, Numerische Mathematik, vol.4, issue.1, pp.269-271, 1959. ,
DOI : 10.1007/BF01386390
CUDA application design and development, 2011. ,
Network flow theory, 1956. ,
Accelerating Large Graph Algorithms on the GPU Using CUDA, High performance computing?HiPC, pp.197-208, 2007. ,
DOI : 10.1007/978-3-540-77220-0_21
Large graph algorithms for massively multithreaded architectures. International Institute of Information Technology Hyderabad, Tech. Rep. IIIT/TR, vol.74, 2009. ,
CuSha, Proceedings of the 23rd international symposium on High-performance parallel and distributed computing, HPDC '14, pp.239-252, 2014. ,
DOI : 10.1145/2600212.2600227
A modified parallel approach to Single Source Shortest Path Problem for massively dense graphs using CUDA, 2011 2nd International Conference on Computer and Communication Technology (ICCCT-2011), pp.635-639, 2011. ,
DOI : 10.1109/ICCCT.2011.6075214
Deploying Graph Algorithms on GPUs: An Adaptive Solution, 2013 IEEE 27th International Symposium on Parallel and Distributed Processing, pp.1013-1024, 2013. ,
DOI : 10.1109/IPDPS.2013.101
CUDA Solutions for the SSSP Problem, International Conference on Computational Science, pp.904-913, 2009. ,
DOI : 10.1007/978-3-642-01970-8_91
Delta-Stepping: A Parallel Single Source Shortest Path Algorithm, Proceedings of the 6th Annual European Symposium on Algorithms, ESA '98, pp.393-404, 1998. ,
DOI : 10.1007/3-540-68530-8_33
Atomic-free irregular computations on GPUs, Proceedings of the 6th Workshop on General Purpose Processor Using Graphics Processing Units, GPGPU-6, pp.96-107, 2013. ,
DOI : 10.1145/2458523.2458533
URL : http://iss.ices.utexas.edu/Publications/Papers/nasre13-gpgpu.pdf
Comprehensive Evaluation of a New GPU-based Approach to the Shortest Path Problem, International Journal of Parallel Programming, vol.54, issue.10, pp.918-938, 2015. ,
DOI : 10.1145/1951365.1951406
A new GPUbased approach to the shortest path problem, High performance computing and simulation (HPCS), pp.505-511, 2013. ,
Algorithms for VLSI physical design automation, 2012. ,
DOI : 10.1007/978-1-4615-2351-2
Applications of graph theory in computer science an overview, International Journal of Engineering Science and Technology, vol.2, issue.9, pp.4610-4621, 2010. ,
The Boost Graph Library: User Guide and Reference Manual, Portable Documents, 2001. ,
Modified Dijkstra's algorithm for dense graphs on GPU using CUDA, Indian Journal of Science and Technology, vol.9, issue.33, p.2016 ,
Efficient parallel implementation of single source shortest path algorithm on GPU using CUDA, International Journal of Applied Engineering Research, vol.11, issue.4, pp.2560-2567, 2016. ,
Shortest-path queries in static networks, ACM Computing Surveys, vol.46, issue.4, p.45, 2014. ,
DOI : 10.1016/S0968-090X(97)00004-1
Gunrock: A High-performance Graph Processing Library on the GPU, Proceedings of the 21st ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming , PPoPP '16, pp.1-1112, 2016. ,
Medusa: Simplified Graph Processing on GPUs, IEEE Transactions on Parallel and Distributed Systems, vol.25, issue.6, pp.1543-1552, 2014. ,
DOI : 10.1109/TPDS.2013.111
