Conference papers
Inverse Multi-objective Shortest Path Problem Under the Bottleneck Type Weighted Hamming Distance
Abstract : Given a network $G(N,\!A,\!C)$ and a directed path $P^0$ from the source node s to the sink node t, an inverse multi-objective shortest path problem is to modify the cost matrix C so that $P^0$ becomes an efficient path and the modification is minimized. In this paper, the modification is measured by the bottleneck type weighted Hamming distance and is proposed an algorithm to solve the inverse problem. Our proposed algorithm can be applied for some other inverse multiobjective problem. As an example, we will mention how the algorithm is used to solve the inverse multi-objective minimum spanning tree problem under the bottleneck type weighted Hamming distance.
Document type :
Conference papers
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01760645
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, April 6, 2018 - 3:08:14 PM
Last modification on : Monday, April 25, 2022 - 2:44:02 PM
File
440117_1_En_4_Chapter.pdf
Identifiers
Citation
Mobarakeh Karimi, Massoud Aman, Ardeshir Dolati. Inverse Multi-objective Shortest Path Problem Under the Bottleneck Type Weighted Hamming Distance. 2nd International Conference on Topics in Theoretical Computer Science (TTCS), Sep 2017, Tehran, Iran. pp.34-40, ⟨10.1007/978-3-319-68953-1_4⟩. ⟨hal-01760645⟩
Share
Metrics
Record views
240
Files downloads
88
