Gray-Box Conformance Testing for Symbolic Reactive State Machines - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1) , (1)
1
Masoumeh Taromirad
  • Function : Author
  • PersonId : 1030395
Mohammad Reza Mousavi
  • Function : Author
  • PersonId : 999386
Model-based testing (MBT) is typically a black-box testing technique. Therefore, generated test suites may leave some untested gaps in a given implementation under test (IUT). We propose an approach to use the structural and behavioural information exploited from the implementation domain to generate effective and efficient test suites. Our approach considers both specification models and implementation models, and generates an enriched test model which is used to automatically generate test suites. We show that the proposed approach is sound and exhaustive and cover both the specification and the implementation. We examine the applicability and the effectiveness of our approach by applying it to a well-known example from the railway domain.
459025_1_En_15_Chapter.pdf (1.07 Mo) Télécharger le fichier
Dates and versions
hal-01760861 , version 1 (06-04-2018)
Attribution - CC BY 4.0
Identifiers
Cite
Masoumeh Taromirad, Mohammad Reza Mousavi. Gray-Box Conformance Testing for Symbolic Reactive State Machines. 7th International Conference on Fundamentals of Software Engineering (FSEN), Apr 2017, Teheran, Iran. pp.228-243, ⟨10.1007/978-3-319-68972-2_15⟩. ⟨hal-01760861⟩
107 View
66 Download
Share
