Comparison of the Time-Delay Margin of a Distributed and Centralized Observer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The benefit of a distributed observer concept for large-scale linear plants is shown by taking time-delays into account. It is asserted that a centralized observer suffers from delays in the measurement input, while a distributed structure allows to avoid them. In contrast, the network of the distributed observer induces communication delays among observer nodes. The delay margins for both observer concepts are estimated on a numerical example and compared using an eigenvalue-based frequency domain approach and an LMI based time-domain approach.
SUEMRF_ECC18.pdf (188.22 Ko) Télécharger le fichier
hal-01761390 , version 1 (09-04-2018)
hal-01761390 , version 2 (07-11-2019)
  • HAL Id : hal-01761390 , version 2
Haik Silm, Rosane Ushirobira, Denis Efimov, Wim Michiels, Jean-Pierre Richard, et al.. Comparison of the Time-Delay Margin of a Distributed and Centralized Observer. ECC 2018 - European Control Conference, Jun 2018, Limassol, Cyprus. ⟨hal-01761390v2⟩
210 Consultations
222 Téléchargements
