Nonlinear Observers and Applications, Lecture Notes in Control and Information Sciences, vol.363, 2007. ,
Introduction to Hybrid Systems, 2005. ,
DOI : 10.1007/0-8176-4404-0_5
Convex conditions for robust stability analysis and stabilization of linear aperiodic impulsive and sampled-data systems under dwell-time constraints, Automatica, vol.49, issue.11, pp.3449-3457, 2013. ,
DOI : 10.1016/j.automatica.2013.08.022
Dwell-time stability and stabilization conditions for linear positive impulsive and switched systems, Nonlinear Analysis: Hybrid Systems, vol.24, pp.198-226, 2017. ,
DOI : 10.1016/j.nahs.2017.01.004
Fault detection in uncertain LPV systems with imperfect scheduling parameter using sliding mode observers, European Journal of Control, vol.34, pp.1-15, 2017. ,
DOI : 10.1016/j.ejcon.2016.12.001
Interval observers for continuous-time LPV systems with <mml:math altimg="si1.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msub><mml:mrow><mml:mi>L</mml:mi></mml:mrow><mml:mrow><mml:mn>1</mml:mn></mml:mrow></mml:msub></mml:math>/<mml:math altimg="si2.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msub><mml:mrow><mml:mi>L</mml:mi></mml:mrow><mml:mrow><mml:mn>2</mml:mn></mml:mrow></mml:msub></mml:math> performance, Automatica, vol.58, pp.82-89, 2015. ,
DOI : 10.1016/j.automatica.2015.05.009
Stabilization of impulsive switched linear systems with saturated control input, Nonlinear Dynamics, vol.54, issue.3, pp.793-804, 2012. ,
DOI : 10.1109/TAC.2008.2010896
Input-to-State Stability of Nonlinear Impulsive Systems, SIAM Journal on Control and Optimization, vol.51, issue.3, pp.1962-1987, 2013. ,
DOI : 10.1137/120881993
Interval observers design for hybrid and biological systems Master's thesis, Université Lille 1 -Sciences et Technologies ; Non-A team, 2015. ,
Interval estimation of sequestered infected erythrocytes in malaria patients, 2016 European Control Conference (ECC), 2016. ,
DOI : 10.1109/ECC.2016.7810443
URL : https://hal.archives-ouvertes.fr/hal-01295741
Interval observer approach to output stabilization of linear impulsive systems, Proc. of the 20th World Congress of the International Federation of Automatic Control, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01508772
Interval Observers for Linear Impulsive Systems, Proc. of 10th IFAC Symposium on Nonlinear Control Systems(IFAC NOLCOS), 2016. ,
DOI : 10.1016/j.ifacol.2016.10.275
URL : https://hal.archives-ouvertes.fr/hal-01356972
Comparison of backstepping control and inversion-based control of a range extender electric vehicle, Proc. of IEEE Vehicle Power and Propulsion Conference (VPPC), 2014. ,
Model-based fault diagnosis techniques, 2008. ,
DOI : 10.1007/978-1-4471-4799-2
Interval estimation for LPV systems applying high order sliding mode techniques, Automatica, vol.48, issue.9, pp.2365-2371, 2012. ,
DOI : 10.1016/j.automatica.2012.06.073
URL : https://hal.archives-ouvertes.fr/hal-00701643
Interval Observers for Time-Varying Discrete-Time Systems, IEEE Transactions on Automatic Control, vol.58, issue.12, pp.3218-3224, 2013. ,
DOI : 10.1109/TAC.2013.2263936
URL : https://hal.archives-ouvertes.fr/hal-01126241
Interval estimation for uncertain systems with time-varying delays, International Journal of Control, vol.23, issue.6, pp.1777-1787, 2013. ,
DOI : 10.1109/TAC.2011.2142590
URL : https://hal.archives-ouvertes.fr/hal-00813314
Delay-dependent positivity: Application to interval observers, 2015 European Control Conference (ECC), 2015. ,
DOI : 10.1109/ECC.2015.7330845
URL : https://hal.archives-ouvertes.fr/hal-01140336
Interval observer design for estimation and control of time-delay descriptor systems, European Journal of Control, vol.23, issue.5, pp.26-35, 2015. ,
DOI : 10.1016/j.ejcon.2015.01.004
URL : https://hal.archives-ouvertes.fr/hal-01108432
Design of interval observers for uncertain dynamical systems, Automation and Remote Control, vol.14, issue.4, pp.1-29, 2015. ,
DOI : 10.1016/j.inffus.2013.02.006
URL : https://hal.archives-ouvertes.fr/hal-01276439
Estimation and control of discrete-time LPV systems using interval observers, 52nd IEEE Conference on Decision and Control, 2013. ,
DOI : 10.1109/CDC.2013.6760679
URL : https://hal.archives-ouvertes.fr/hal-01126277
Design of interval observers for estimation and stabilization of discrete-time LPV systems, IMA Journal of Mathematical Control and Information, vol.24, issue.4, pp.1-16, 2015. ,
DOI : 10.2514/3.20997
URL : https://hal.archives-ouvertes.fr/hal-01162680
Control of Nonlinear and LPV Systems: Interval Observer-Based Framework, IEEE Transactions on Automatic Control, vol.58, issue.3, pp.773-782, 2013. ,
DOI : 10.1109/TAC.2013.2241476
URL : https://hal.archives-ouvertes.fr/hal-00664106
A separation principle for linear impulsive systems, European Journal of Control, vol.20, issue.3, pp.105-110, 2014. ,
DOI : 10.1016/j.ejcon.2014.02.001
URL : https://hal.archives-ouvertes.fr/hal-01066396
Positive Linear Systems: Theory and Applications, 2000. ,
DOI : 10.1002/9781118033029
Using Luenberger observers and dwell-time logic for feedback hybrid loops in continuous-time control systems, International Journal of Robust and Nonlinear Control, vol.52, issue.12, pp.1065-1086, 2013. ,
DOI : 10.1109/TAC.2007.910684
URL : https://hal.archives-ouvertes.fr/hal-00830556
New Directions in Nonlinear Observer Design, 1999. ,
A torque and speed coupling hybrid drivetrain-architecture, control, and simulation, IEEE Transactions on Power Electronics, vol.21, issue.3, pp.741-748, 2006. ,
Hybrid Dynamical Systems: Modeling, Stability, and Robustness, 2012. ,
Interval observers for uncertain biological systems, Ecological Modelling, vol.133, issue.1-2, pp.46-56, 2000. ,
DOI : 10.1016/S0304-3800(00)00279-9
On Input-to-State Stability of Impulsive Systems, Proceedings of the 44th IEEE Conference on Decision and Control, 2005. ,
DOI : 10.1109/CDC.2005.1582786
Lyapunov conditions for input-to-state stability of impulsive systems, Automatica, vol.44, issue.11, pp.442735-2744, 2008. ,
DOI : 10.1016/j.automatica.2008.03.021
Stabilization of linear impulsive systems through a nearly-periodic reset. Nonlinear Analysis: Hybrid systems, pp.4-15, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00734728
Recent developments on the stability of systems with aperiodic sampling: An overview, Automatica, vol.76, pp.309-335, 2017. ,
DOI : 10.1016/j.automatica.2016.10.023
URL : https://hal.archives-ouvertes.fr/hal-01363448
Monotone maps: a review, Journal of Difference Equations and Applications, vol.21, issue.4-5, pp.379-398, 2005. ,
DOI : 10.1017/S0004972700017032
YALMIP : a toolbox for modeling and optimization in MATLAB, 2004 IEEE International Conference on Robotics and Automation (IEEE Cat. No.04CH37508), 2004. ,
DOI : 10.1109/CACSD.2004.1393890
Asymptotically Stable Interval Observers for Planar Systems With Complex Poles, IEEE Transactions on Automatic Control, vol.55, issue.2, pp.523-527, 2010. ,
DOI : 10.1109/TAC.2009.2037472
URL : https://hal.archives-ouvertes.fr/hal-00547800
Interval observers for linear time-invariant systems with disturbances, Automatica, vol.47, issue.1, pp.140-147, 2011. ,
DOI : 10.1016/j.automatica.2010.10.019
URL : https://hal.archives-ouvertes.fr/hal-00555464
Robust interval observers and stabilization design for discrete-time systems with input and output, Automatica, vol.49, issue.11, pp.3490-3497, 2013. ,
DOI : 10.1016/j.automatica.2013.09.016
URL : https://hal.archives-ouvertes.fr/hal-00874971
Interval observers for discrete-time systems, International Journal of Robust and Nonlinear Control, vol.59, issue.4, pp.2867-2890, 2014. ,
DOI : 10.1016/j.sysconle.2010.08.005
URL : https://hal.archives-ouvertes.fr/hal-01088147
Exponentially Stable Interval Observers for Linear Systems with Delay, SIAM Journal on Control and Optimization, vol.50, issue.1, pp.286-305, 2012. ,
DOI : 10.1137/100812124
URL : https://hal.archives-ouvertes.fr/hal-00761603
State estimation for linear impulsive systems, 2009 American Control Conference, pp.1183-1188, 2009. ,
DOI : 10.1109/ACC.2009.5160347
Exponential stability of impulsive systems with application to uncertain sampled-data systems, Systems & Control Letters, vol.57, issue.5, pp.378-385, 2008. ,
DOI : 10.1016/j.sysconle.2007.10.009
SOSTOOLS: Sum of squares optimization toolbox for MATLAB v3, p.0, 2013. ,
Stability for impulsive control systems, Dynamical Systems, vol.17, issue.4, pp.421-434, 2002. ,
DOI : 10.1080/1468936031000075151
Interval State Estimation for a Class of Nonlinear Systems, IEEE Transactions on Automatic Control, vol.57, issue.1, pp.260-265, 2012. ,
DOI : 10.1109/TAC.2011.2164820
Estimation of linear positive systems with unknown time-varying delays, European Journal of Control, vol.19, issue.3, pp.179-187, 2013. ,
DOI : 10.1016/j.ejcon.2013.05.001
Monotone dynamical systems, 1995. ,
DOI : 10.1090/surv/041/01
Modeling of power split device with clutch for heavy-duty millitary vehicles, 2011 IEEE Vehicle Power and Propulsion Conference, 2011. ,
DOI : 10.1109/VPPC.2011.6043134
Observability for Switched Linear Systems: Characterization and Observer Design, IEEE Transactions on Automatic Control, vol.58, issue.4, pp.891-904, 2013. ,
DOI : 10.1109/TAC.2012.2224257
Negative friction coefficients, Nature Materials, vol.24, issue.6, p.468, 2013. ,
DOI : 10.1021/la703229n
Robust Fault Detection Observer and Fault Estimation Filter Design for LTI Systems Based on GKYP Lemma, European Journal of Control, vol.16, issue.4, pp.366-383, 2010. ,
DOI : 10.3166/ejc.16.366-383
