Asymptotic Modeling of the Electromagnetic Scattering by Small Spheres Perfectly Conducting
Abstract : In this paper, we develop a method of matched asymptotic expansions for solving the time-harmonic electromagnetic scattering problem by a small sphere perfectly conducting. This method consists in defining an approximate solution using multi-scale expansions over far and near fields, related in a matching area. We make explicit the asymptotics up to the second order of approximation for the near-field expansion and up to the fifth order of approximation for the far-field expansion. We illustrate the results with numerical experiments which make evident the performance of the asymptotic models. The reference solution is an analytical solution computed thanks to Montjoie code.
Complete list of metadatas
Cited literature [35 references]  Display  Hide  Download
https://hal.inria.fr/hal-01762625
Contributor : Justine Labat <>
Submitted on : Tuesday, April 10, 2018 - 11:54:10 AM
Last modification on : Monday, September 9, 2019 - 9:06:02 AM
File
RR-9169.pdf
Identifiers
  • HAL Id : hal-01762625, version 1
Citation
Justine Labat, Victor Péron, Sébastien Tordeux. Asymptotic Modeling of the Electromagnetic Scattering by Small Spheres Perfectly Conducting. [Research Report] RR-9169, Université de Pau et des Pays de l'Adour; Inria Bordeaux Sud-Ouest; LMAP UMR CNRS 5142. 2018. ⟨hal-01762625v1⟩
Share
Metrics
Record views
107
Files downloads
82
