Cache-Based Side-Channel Attacks Detection through Intel Cache Monitoring Technology and Hardware Performance Counters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Research on cache-based side-channel attacks shows the security impact of these attacks on cloud computing. Therefore , the detection of cache-based side-channel attacks has received more attention in IaaS cloud infrastructures because of improvements in the attack techniques. However, such detection requires high resolution information, and it is also a challenging task because of the fine-granularity of the attacks. In this paper, we present an approach to detect cross-VM cache-based side-channel attacks through using hardware fine-grained information provided by Intel Cache Monitoring Technology (CMT) and Hardware Performance Counters (HPCs) following the Gaussian anomaly detection method. The approach shows a high detection rate with 2% performance overhead on the computing platform.
fmec2018_draft.pdf (299.06 Ko) Télécharger le fichier
hal-01762803 , version 1 (10-04-2018)
hal-01762803 , version 2 (14-09-2018)
Mohammad-Mahdi Bazm, Thibaut Sautereau, Marc Lacoste, Mario Südholt, Jean-Marc Menaud. Cache-Based Side-Channel Attacks Detection through Intel Cache Monitoring Technology and Hardware Performance Counters. FMEC 2018 - Third IEEE International Conference on Fog and Mobile Edge Computing, Apr 2018, Barcelona, Spain. pp.1-6, ⟨10.1109/FMEC.2018.8364038⟩. ⟨hal-01762803v2⟩
959 Consultations
2326 Téléchargements
