Flow Control by Feedback, Stabilization and Mixing, 2003. ,
Nonoscillation Theory of Functional Differential Equations with Applications ,
DOI : 10.1007/978-1-4614-3455-9
Closed-Loop Turbulence Control: Progress and Challenges, ASME Applied Mechanics Reviews, vol.67, issue.5, pp.1-48, 2015. ,
Nonlinear Partial Differential Equations for Scientists and Engineers, 2012. ,
DOI : 10.1007/b138648
Nonlinear active control of turbulent separated flows: Theory and experiments, 2017. ,
SISO model-based control of separated flows: Sliding mode and optimal control approaches, International Journal of Robust and Nonlinear Control, vol.58, issue.3, pp.5008-5027, 2017. ,
DOI : 10.1017/CBO9780511618864
URL : https://hal.archives-ouvertes.fr/hal-01587824
A bilinear input-output model with state-dependent delay for separated flow control, 2016 European Control Conference (ECC), pp.1679-1684, 2016. ,
DOI : 10.1109/ECC.2016.7810532
URL : https://hal.archives-ouvertes.fr/hal-01298166
Differential equations with discontinuous right?hand side. Kluwer. Dordrecht, The Netherlands, 1988. ,
Introduction to Time-Delay Systems, 2014. ,
DOI : 10.1007/978-3-319-09393-2
Volterra Integral and Functional Equations, 1990. ,
DOI : 10.1017/CBO9780511662805
Oscillation Theory of Delay Differential Equations With Applications, 1991. ,
Comments on " robust stabilization of uncertain input-delay systems by sliding mode control with delay compensation, Automatica, vol.37, issue.10, p.1677, 2001. ,
Minimization of disturbances effects in time delay predictor-based sliding mode control systems, Journal of the Franklin Institute, vol.349, issue.4, pp.1380-1396, 2012. ,
DOI : 10.1016/j.jfranklin.2011.06.028
Stability notions and Lyapunov functions for sliding mode control systems, Journal of the Franklin Institute, vol.351, issue.4, pp.1831-1865, 2014. ,
DOI : 10.1016/j.jfranklin.2014.01.002
URL : https://hal.archives-ouvertes.fr/hal-00942319
Sliding Modes in Control and Optimization, 1992. ,
DOI : 10.1007/978-3-642-84379-2
Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009. ,
DOI : 10.1080/10241230306724
URL : http://doi.org/10.1080/10241230306724
