Analysis of the Robustness of Production Scheduling in Aeronautical Manufacturing Using Simulation: A Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
R. Pulido
  • Fonction : Auteur
  • PersonId : 1030657
T. Borreguero-Sanchidrián
  • Fonction : Auteur
  • PersonId : 1030658
A. García-Sánchez
  • Fonction : Auteur
  • PersonId : 1030659
M. Ortega-Mier
  • Fonction : Auteur
  • PersonId : 991648
The use of PLM tools is widely spread in the aeronautical industry. Although scheduling and line balancing have remained aside these tools for long, they are being developed in the recent years. They need to tackle with complex resource constrained scheduling problems. In this work we present a simulation model we have developed for evaluating the robustness of a baseline scheduling for an aero structure assembly line. To begin with, we have identified and quantified the main causes of the disruptions. Then we have created a discrete event simulation model of the production line to take everything into consideration, and then run several experiments to evaluate different production planning obtained with the different methodologies and the impact of failures in the deliveries of finished products. Also, different scenarios in terms of failure quantity and typology have been studied.
462132_1_En_16_Chapter.pdf (360.63 Ko) Télécharger le fichier
hal-01764161 , version 1 (11-04-2018)
Paternité
R. Pulido, T. Borreguero-Sanchidrián, A. García-Sánchez, M. Ortega-Mier. Analysis of the Robustness of Production Scheduling in Aeronautical Manufacturing Using Simulation: A Case Study. 14th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2017, Seville, Spain. pp.174-183, ⟨10.1007/978-3-319-72905-3_16⟩. ⟨hal-01764161⟩
58 Consultations
101 Téléchargements
