Managing Maturity States in a Collaborative Platform for the iDMU of Aeronautical Assembly Lines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ignacio Eguía
  • Fonction : Auteur
  • PersonId : 1030674
Manuel Oliva
  • Fonction : Auteur
  • PersonId : 1030675
Fernando Mas
  • Fonction : Auteur
  • PersonId : 1000803
Collaborative Engineering aims to integrate both functional and industrial design. This goal requires integrating the design processes, the design teams and using a single common software platform to hold all the stakeholders contributions. Airbus company coined the concept of the industrial Digital Mock Up (iDMU) as the necessary unique deliverable to perform the design process with a unique team. Previous virtual manufacturing projects confirmed the potential of the iDMU to improve the industrial design process in a collaborative engineering environment. This paper presents the methodology and preliminary results for the management of the maturity states of the iDMU with all product, process and resource information associated with the assembly of an aeronautical component. The methodology aims to evaluate the suitability of a PLM platform to implement the iDMU in the creation of a control mechanism that allows a collaborative work.
462132_1_En_59_Chapter.pdf (493.27 Ko) Télécharger le fichier
hal-01764172 , version 1 (11-04-2018)
Paternité
Domingo Morales-Palma, Ignacio Eguía, Manuel Oliva, Fernando Mas, Carpóforo Vallellano. Managing Maturity States in a Collaborative Platform for the iDMU of Aeronautical Assembly Lines. 14th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2017, Seville, Spain. pp.667-676, ⟨10.1007/978-3-319-72905-3_59⟩. ⟨hal-01764172⟩
148 Consultations
559 Téléchargements
