Role of VR Throughout the Life of Low Volume Products Towards Digital Extended Enterprises
This paper discusses the role of virtual reality from the perspective of PLM, based on several industrial case studies. As a result of the research a virtual reality in PLM utilization model is proposed. The proposed model regards virtual reality value creation and prerequisites from PLM perspective. Utility of the model is discussed from business management point of view.
Informatique [cs]
