Automatic Configuration of Modularized Products - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stefano Amato
  • Fonction : Auteur
  • PersonId : 1030694
Alfredo Fantetti
  • Fonction : Auteur
  • PersonId : 1030695
Andrea Radaelli
  • Fonction : Auteur
  • PersonId : 1030696
Alex Saja
  • Fonction : Auteur
  • PersonId : 1030697
Paolo Chiabert
  • Fonction : Auteur
  • PersonId : 990128
In business to business manufacturing, a major competitive advantage comes from the personalization of the product for the customer. In order to customize a product, companies go through a long process of customer interviews and specialized product development processes: this results in a time-consuming design phase and in a highly variable production process. In this paper, a method to improve the efficiency of product development and manufacturing, keeping a high degree of customization, is presented. A standardization effort is performed to identify a set of interchangeable components and to define a set of functional constraints. The consequences of such standardization are a dramatic reduction of the time expected to design and produce an item, as well as in lowered degree of variability of both the manufacturing process and the warehouses content. The presented methodology has been applied to a manufacturer of ink dispensing systems.
462132_1_En_38_Chapter.pdf (854.31 Ko) Télécharger le fichier
hal-01764189 , version 1 (11-04-2018)
Paternité
Joel Sauza-Bedolla, Stefano Amato, Alfredo Fantetti, Andrea Radaelli, Alex Saja, et al.. Automatic Configuration of Modularized Products. 14th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2017, Seville, Spain. pp.429-439, ⟨10.1007/978-3-319-72905-3_38⟩. ⟨hal-01764189⟩
64 Consultations
112 Téléchargements
