PLM-MES Integration to Support Industry 4.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Lisa Macheda
  • Fonction : Auteur
  • PersonId : 1030705
Paolo Chiabert
  • Fonction : Auteur
  • PersonId : 990128
In order to effectively deal with the Industry 4.0 paradigm, companies need accurate strategies to manage data collected on both the real world and its virtual counterpart. Proper information systems need to be implemented; Product Lifecycle Management (PLM) and Manufacturing Execution Systems (MES) play a key role in this task. A primary issue is the mutual integration of such systems, with the aim of reducing time and cost for data management, as well as risks of errors and data redundancy. The present paper aims to present the results of a survey submitted to a set of Italian companies to measure their digital maturity and their proneness in implementing further information systems and in enabling their integration.
462132_1_En_12_Chapter.pdf (546.54 Ko) Télécharger le fichier
hal-01764194 , version 1 (11-04-2018)
Paternité
Gianluca D’antonio, Lisa Macheda, Joel Sauza Bedolla, Paolo Chiabert. PLM-MES Integration to Support Industry 4.0. 14th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2017, Seville, Spain. pp.129-137, ⟨10.1007/978-3-319-72905-3_12⟩. ⟨hal-01764194⟩
363 Consultations
657 Téléchargements
