Timely Dataflow: A Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper studies timely dataflow, a model for data-parallel computing in which each communication event is associated with a virtual time. It defines and investigates the could-result-in relation which is central to this model, then the semantics of timely dataflow graphs.
978-3-319-19195-9_9_Chapter.pdf (298.82 Ko) Télécharger le fichier
hal-01767326 , version 1 (16-04-2018)
Paternité
Martín Abadi, Michael Isard. Timely Dataflow: A Model. 35th International Conference on Formal Techniques for Distributed Objects, Components, and Systems (FORTE), Jun 2015, Grenoble, France. pp.131-145, ⟨10.1007/978-3-319-19195-9_9⟩. ⟨hal-01767326⟩
69 Consultations
223 Téléchargements
