Observational Semantics for Dynamic Logic with Binders - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The dynamic logic with binders $$\mathcal {D}^{\downarrow }$$ was recently introduced as a suitable formalism to support a rigorous stepwise development method for reactive software. The commitment of this logic concerning bisimulation equivalence is, however, not satisfactory: the model class semantics of specifications in $$\mathcal {D}^{\downarrow }$$ is not closed under bisimulation equivalence; there are $$\mathcal {D}^{\downarrow }$$-sentences that distinguish bisimulation equivalent models, i.e., $$\mathcal {D}^{\downarrow }$$ does not enjoy the modal invariance property. This paper improves on these limitations by providing an observational semantics for dynamic logic with binders. This involves the definition of a new model category and of a more relaxed satisfaction relation. We show that the new logic $$\mathcal {D}^{\downarrow }_\sim $$ enjoys modal invariance and even the Hennessy-Milner property. Moreover, the new model category provides a categorical characterisation of bisimulation equivalence by observational isomorphism. Finally, we consider abstractor semantics obtained by closing the model class of a specification $$ SP $$ in $$\mathcal {D}^{\downarrow }$$ under bisimulation equivalence. We show that, under mild conditions, abstractor semantics of $$ SP $$ in $$\mathcal {D}^{\downarrow }$$ is the same as observational semantics of $$ SP $$ in $$\mathcal {D}^{\downarrow }_\sim $$.
433330_1_En_10_Chapter.pdf (349.25 Ko) Télécharger le fichier
hal-01767472 , version 1 (16-04-2018)
Paternité
Rolf Hennicker, Alexandre Madeira. Observational Semantics for Dynamic Logic with Binders. 23th International Workshop on Algebraic Development Techniques (WADT), Sep 2016, Gregynog, United Kingdom. pp.135-152, ⟨10.1007/978-3-319-72044-9_10⟩. ⟨hal-01767472⟩
32 Consultations
58 Téléchargements
