Image reconstruction through metamorphosis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems Année : 2020
This article adapts the framework of metamorphosis to the resolution of inverse problems with shape prior. The metamorphosis framework allows to transform an image via a balance between geometrical deformations and changes in intensities (that can for instance correspond to the appearance of a new structure). The idea developed here is to reconstruct an image from noisy and indirect observations by registering, via metamorphosis, a template to the observed data. Unlike a registration with only geometrical changes, this framework gives good results when intensities of the template are poorly chosen. We show that this method is a well-defined regularization method (proving existence, stability and convergence) and present several numerical examples.
ReconstructionMetamorphosis.pdf (3.33 Mo) Télécharger le fichier
hal-01773633 , version 1 (23-04-2018)
hal-01773633 , version 2 (04-06-2018)
hal-01773633 , version 3 (29-11-2019)
Ozan Öktem, Barbara Gris, Chong Chen. Image reconstruction through metamorphosis. Inverse Problems, 2020, 36, ⟨10.1088/1361-6420/ab5832⟩. ⟨hal-01773633v3⟩
698 Consultations
259 Téléchargements
