A little more conversation, a little less action, a lot more satisfaction: Global states in ProVerif - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2018
Vincent Cheval
Véronique Cortier
  • Fonction : Auteur
  • PersonId : 830860
Mathieu Turuani
  • Fonction : Auteur
  • PersonId : 835628
ProVerif is a popular tool for the fully automatic analysis of security protocols, offering very good support to detect flaws or prove security. One exception is the case of protocols with global states such as counters, tables, or more generally, memory cells. ProVerif fails to analyse such protocols, due to its internal abstraction. Our key idea is to devise a generic transformation of the security properties queried to ProVerif. We prove the soundness of our transformation and implement it into a front-end GSVerif. Our experiments show that our front-end (combined with ProVerif) outperforms the few existing tools, both in terms of efficiency and protocol coverage. We successfully apply our tool to a dozen of protocols of the literature, yielding the first fully automatic proof of a security API and a payment protocol of the literature.
CCT-CSF18-Technical Report.pdf (447.21 Ko) Télécharger le fichier
hal-01774803 , version 1 (23-04-2018)
hal-01774803 , version 2 (29-04-2018)
  • HAL Id : hal-01774803 , version 2
Vincent Cheval, Véronique Cortier, Mathieu Turuani. A little more conversation, a little less action, a lot more satisfaction: Global states in ProVerif. [Research Report] Inria Nancy - Grand Est; LORIA, UMR 7503, Université de Lorraine, CNRS, Vandoeuvre-lès-Nancy. 2018. ⟨hal-01774803v2⟩
181 Consultations
562 Téléchargements
