Klaim-DB: A Modeling Language for Distributed Database Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present the modelling language, Klaim-DB, for distributed database applications. Klaim-DB borrows the distributed nets of the coordination language Klaim but essentially re-incarnates the tuple spaces of Klaim as databases, and provides high-level language abstractions for the access and manipulation of structured data, with integrity and atomicity considerations. We present the formal semantics of Klaim-DB and illustrate the use of the language in a scenario where the sales from different branches of a chain of department stores are aggregated from their local databases. It can be seen that raising the abstraction level and encapsulating integrity checks (concerning the schema of tables, etc.) in the language primitives for database operations benefit the modelling task considerably.
978-3-319-19282-6_13_Chapter.pdf (398.18 Ko) Télécharger le fichier
hal-01774934 , version 1 (24-04-2018)
Paternité
Xi Wu, Ximeng Li, Alberto Lluch Lafuente, Flemming Nielson, Hanne Riis Nielson. Klaim-DB: A Modeling Language for Distributed Database Applications. 17th International Conference on Coordination Languages and Models (COORDINATION), Jun 2015, Grenoble, France. pp.197-212, ⟨10.1007/978-3-319-19282-6_13⟩. ⟨hal-01774934⟩
321 Consultations
64 Téléchargements
