An augmented lagrangian approach to constrained map inference, Proceedings of the 28th International Conference on Machine Learning (ICML-11), pp.169-176, 2011. ,
Integer programming for combinatorial auction winner determination, Proceedings Fourth International Conference on MultiAgent Systems, pp.39-46, 2000. ,
DOI : 10.1109/ICMAS.2000.858429
Heuristics based on mathematical programming. Surveys in Operations Research and Management Science, pp.21-38, 2011. ,
Introduction to Linear Optimization, Athena Scientific, 1997. ,
Distributed Optimization and Statistical Learning via the Alternating Direction Method of Multipliers, Foundations and Trends?? in Machine Learning, vol.3, issue.1, pp.1-122, 2011. ,
DOI : 10.1561/2200000016
Combinatorial Auctions: A Survey, INFORMS Journal on Computing, vol.15, issue.3, pp.284-309, 2003. ,
DOI : 10.1287/ijoc.15.3.284.16077
Efficient projections onto the l 1- ball for learning in high dimensions, Proceedings of the 25th international conference on Machine learning, pp.272-279, 2008. ,
On the Douglas???Rachford splitting method and the proximal point algorithm for maximal monotone operators, Mathematical Programming, vol.29, issue.1, pp.293-318, 1992. ,
DOI : 10.2140/pjm.1970.33.209
Taming the computational complexity of combinatorial auctions: Optimal and approximate approaches, International Joint Conferences on Artificial Intelligence (IJCAI), pp.548-553, 1999. ,
A dual algorithm for the solution of nonlinear variational problems via finite element approximation, Computers & Mathematics with Applications, vol.2, issue.1, pp.17-40, 1976. ,
DOI : 10.1016/0898-1221(76)90003-1
Fixing max-product: Convergent message passing algorithms for map lp-relaxations, Advances in neural information processing systems, pp.553-560, 2008. ,
Sur l'approximation, parélémentspar´paréléments finis d'ordre un, et la résolution, par pénalisation-dualité d'une classe deprobì emes de dirichlet non linéaires, ESAIM: Mathematical Modelling and Numerical Analysis-Modélisation Mathématique et Analyse Numérique, vol.9, issue.R2, pp.41-76, 1975. ,
Norm-Product Belief Propagation: Primal-Dual Message-Passing for Approximate Inference, IEEE Transactions on Information Theory, vol.56, issue.12, pp.6294-6316, 2010. ,
DOI : 10.1109/TIT.2010.2079014
Convergent tree-reweighted message passing for energy minimization. Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.28, issue.10, pp.1568-1583, 2006. ,
MRF Optimization via Dual Decomposition: Message-Passing Revisited, 2007 IEEE 11th International Conference on Computer Vision, pp.1-8, 2007. ,
DOI : 10.1109/ICCV.2007.4408890
URL : http://www.mas.ecp.fr/Personnel/nikos/pub/iccv07.pdf
Empirical hardness models, Journal of the ACM, vol.56, issue.4, p.22, 2009. ,
DOI : 10.1145/1538902.1538906
Towards a universal test suite for combinatorial auction algorithms, Proceedings of the 2nd ACM conference on Electronic commerce , EC '00, pp.66-76, 2000. ,
DOI : 10.1145/352871.352879
The Geometry of Constrained Structured Prediction: Applications to Inference and Learning of Natural Language Syntax, 2012. ,
Ad 3 : Alternating directions dual decomposition for map inference in graphical models, Journal of Machine Learning Research, vol.46, 2014. ,
Distributed non-convex admm-inference in large-scale random fields, British Machine Vision Conference (BMVC), 2014. ,
Auctions and bidding, ACM Computing Surveys, vol.43, issue.2, pp.1-1059, 2011. ,
DOI : 10.1145/1883612.1883617
Trust-based mechanisms for robust and efficient task allocation in the presence of execution uncertainty, Journal of Artificial Intelligence Research, vol.35, issue.1, p.119, 2009. ,
Agent-based coordination technologies in disaster management, Proceedings of the 7th international joint conference on Autonomous agents and multiagent systems: demo papers, pp.1651-1652, 2008. ,
X-Stream, Proceedings of the Twenty-Fourth ACM Symposium on Operating Systems Principles, SOSP '13, pp.472-488, 2013. ,
DOI : 10.1145/2517349.2522740
On dual decomposition and linear programming relaxations for natural language processing, Proceedings of the 2010 Conference on Empirical Methods in Natural Language Processing, pp.1-11, 2010. ,
Cabob: A fast optimal algorithm for combinatorial auctions, International Joint Conference on Artificial Intelligence, pp.1102-1108, 2001. ,
On the generation of alternative explanations with implications for belief revision, Proceedings of the Seventh conference on Uncertainty in Artificial Intelligence, pp.339-347, 1991. ,
Combinatorial Auctions in the Procurement of Transportation Services, Interfaces, vol.34, issue.4, pp.245-252, 2004. ,
DOI : 10.1287/inte.1040.0075
Multiagent Bidding Mechanisms for Robot Qualitative Navigation, Intelligent Agents VII Agent Theories Architectures and Languages, pp.198-212, 2001. ,
DOI : 10.1007/3-540-44631-1_14
Dependency parsing by belief propagation, Proceedings of the Conference on Empirical Methods in Natural Language Processing, EMNLP '08, pp.145-156, 2008. ,
DOI : 10.3115/1613715.1613737
URL : http://dl.acm.org/ft_gateway.cfm?id=1613737&type=pdf
Tightening lp relaxations for map using message passing. arXiv preprint, 2012. ,
Tree-reweighted belief propagation algorithms and approximate ml estimation by pseudo-moment matching, In Workshop on Artificial Intelligence and Statistics Society for Artificial Intelligence and Statistics Np, vol.21, p.97, 2003. ,
Linear programming relaxations and belief propagation ? an empirical study, J. Mach. Learn. Res, vol.7, pp.1887-1907, 2006. ,
