A universal modular actor formalism for artificial intelligence, International Joint Conference on Artificial Intelligence (IJCAI), pp.235-245, 1973. ,
Actor frameworks for the JVM platform, Proceedings of the 7th International Conference on Principles and Practice of Programming in Java, PPPJ '09, pp.11-20, 2009. ,
DOI : 10.1145/1596655.1596658
Speculative Concurrent Processing with Transactional Memory in the Actor Model, International Conference on Principles of Distributed Systems (OPODIS), 2013. ,
DOI : 10.1007/978-3-319-03850-6_12
Identifying the optimal level of parallelism in transactional memory systems, International Conference on Networked Systems (NETYS), pp.233-247, 2013. ,
Adaptive load control in transaction processing systems, 1991. ,
Software transactional memory for dynamic-sized data structures, Proceedings of the twenty-second annual symposium on Principles of distributed computing , PODC '03, pp.92-101, 2003. ,
DOI : 10.1145/872035.872048
Supporting nested transactional memory in logtm, ACM SIGPLAN Notices, issue.11, pp.41-359, 2006. ,
CCSTM: A library-based STM for Scala, Annual Scala Workshop at Scala Days, 2010. ,
A foundation for actor computation, Journal of Functional Programming, vol.7, issue.1, pp.1-72, 1997. ,
DOI : 10.1017/S095679689700261X
On the integration of the actor model in mainstream technologies, Proceedings of the 2nd edition on Programming systems, languages and applications based on actors, agents, and decentralized control abstractions, AGERE! '12, pp.1-6, 2012. ,
DOI : 10.1145/2414639.2414641
Software transactional memories for Scala, Journal of Parallel and Distributed Computing, vol.73, issue.2, pp.150-163, 2013. ,
DOI : 10.1016/j.jpdc.2012.09.015
Transactional Memory, 2010. ,
DOI : 10.1201/b11417-16
Integrating task parallelism with actors, International Conference on Object Oriented Programming Systems Languages and Applications (OOPSLA), pp.753-772, 2012. ,
DOI : 10.1145/2398857.2384671
Parallel actor monitors, In: Brazilian Symposium on Programming Languages, 2010. ,
Stretching transactional memory, ACM SIGPLAN Notices, vol.44, issue.6, pp.155-165, 2009. ,
DOI : 10.1145/1543135.1542494
Multivariate Geostatistics: Beyond Bivariate Moments, Geostatistics Tróia, vol.1, pp.133-144, 1993. ,
DOI : 10.1007/978-94-011-1739-5_12
The Direct Sampling method to perform multiple-point geostatistical simulations, Water Resources Research, vol.39, issue.3, pp.1-14, 2010. ,
DOI : 10.1029/2001WR001146
